Results 1 to 6 of 6
Thread: basic help reqd. astra mk3 grille
    MIGWeb User andrew_lumb's Avatar
    Apr 2004
    Huddersfield
    Skoda Octavia vRS
    how do i remove the grille?
    i have taken indicators out and loosened 3 screws on headlights.. headlights wont seem to come out, and i still cant see how the grill comes off?
    help please guys!
    cheers, andrew
    Aug 2004
    Essex,Nr. Colchester
    2.0 16v Vectra
    Quote Originally Posted by andrew_lumb
    help please guys!
    cheers, andrew
    IIRC 2 clips at the each end the grill under the headlight. then 2 slightly further in that go into the bumber which need to be pushed forwards/backwards then pulled up. and then the clips at the top of the grill which you can see. someone please correct me if im wrong.
    Ya See I Go By The Code Of The Doctor Of The Mix And These Reasons I'll Tell Ya Why...
    Apr 2004
    Huddersfield
    Skoda Octavia vRS
    the two at the top... does it just pull, or do i have to unscrew something, or does it slide up, or what?
    i just dont wanna pull and snap the thing off!
    lol, cheers
    Aug 2004
    2.0 16v Vectra
    you either just pull or there will be some little metal clips holding it in place. if you pull the metal clips will just be forced off anyway.
    Apr 2004
    Huddersfield
    Skoda Octavia vRS
    ive got it now anyway - it was realising how the clips along the top removed.. simple when you know how!
    all i wanted to do was free the airflow up a bit through to the radiator and the air feed to the airbox.. everything was sooo restrictive.. a lot better now though
    cheers dan
    Aug 2004
    2.0 16v Vectra
    No probs
