Results 1 to 10 of 10
Thread: Tigra Sideskirts
    Oct 2004
    Morecambe
    clio
    Tigra Sideskirts
    ive got a 98 reg tigra and rust has appeared behind the standard sideskirts it looks like only surface rust but i dunno how to remove them to get a proper look any help would be great
    Oct 2000
    Portishead
    300ZX TT & Passat R
    Go to a bodyshop and get it done professionally. Will need chopping out.
    Oct 2004
    Morecambe
    clio
    thats ok but i dont have much money at the moment after buying the car so i was looking for a cheaper alternative
    Jun 2004
    Edinburgh
    MK3 Astra Cabrio
    The sideskirts should just clip out
    Aug 2004
    ashford kent
    ford mondeo
    should just unclip, if surface rust sand back treat with rust treatment aka kurust and hammerite.
    Oct 2000
    Portishead
    300ZX TT & Passat R
    Quote Originally Posted by stuboy
    I very much doubt it's surface rust if it's hiding behind a side skirt.
    Dec 2004
    Southampton
    Corsa B GLS 1.4 16v
    simon knows his stuff, his jobs postin on mig lmao
    Oct 2004
    Morecambe
    clio
    well its rust and its got to be sorted cant get them to come off and i dont wanna break it
    Oct 2000
    Portishead
    300ZX TT & Passat R
    Well, they are only held in with clips and lugs. If you look on the underside of the sill, you'll see about 5 of them. These need to be removed. The skirt needs to be eased off the clips. You wont break the skirt, but you may break the clips. They are cheap and easy to replace anyway and are only clipped onto rivets.
    Oct 2004
    Morecambe
    clio
    thanks very much
