Results 1 to 17 of 17
Thread: Removing Seats (Pre-tensioners)
    Aug 2004
    Essex,Nr. Colchester
    2.0 16v Vectra
    I went to remove my seats yesterday and thought it would just be a matter of unbolting, but nothings ever simple is it. I found out I have seatbelt pre-tensioners and would like to know how I remove the seats without these going off?
    Cheers
    Ya See I Go By The Code Of The Doctor Of The Mix And These Reasons I'll Tell Ya Why...
    Mar 2003
    Swansea
    VX220 NA
    On my corsa there is a cylinder with a yellow warning sticker on it. There should be a red fork that you insert into the tensioner and that stops it from activating
    Vauxhall VX220 NA
    Aug 2004
    2.0 16v Vectra
    Quote Originally Posted by welshdude
    will it be fairly obvious where i need to put the fork?
    Mar 2003
    Swansea
    VX220 NA
    Yeah it even tells you how and where to put it on the yellow warning sticker (this was the case in my corsa)
    Vauxhall VX220 NA
    Aug 2004
    2.0 16v Vectra
    Ok, cheers mate. and sorry it was in the wrong section
    Oct 2000
    Portishead
    300ZX TT & Passat R
    Yup, Welsh dude is spot on. Should be a little tab affixed to the tensioner cylinder. You need to insert this at the end closest to the buckle (I think). You'll understand when you get your head down there.
    Jul 2004
    Ayrshire
    Corsa B 1.2 8v
    were can you get the red fork from? i dont have one, any ideas as to how much these are?
    I wish my grass was emo so it would cut itself...
    May 2004
    NW, England
    Corsa X14XE
    i took my seats out without the need for this
    out of an astra mk3 3 door btw
    Jun 2002
    Mirfield
    '99 Vectra 1.8 16V
    On the Vec you need to disconnect the battery for an hour or so beforehand and disconnect the wiring under the seat.
    Jan 2002
    Bradford
    a Crotch Rocket
    They don't go off as easily as you might think. I had a pair of subframes that i wanted to use with some bucket seats and wanted to remove the tensioners. I had to hammer a wedge pretty hard into the rivet that holds the tensioner to the subframe to make them fire.
    Aug 2004
    2.0 16v Vectra
    So should i disconnect the battery for a while before unplugging them or will it be ok to unplug them with the battery still connected? cheers
    Jan 2002
    Bradford
    a Crotch Rocket
    Disconnect it, just to be safe.
    Jul 2000
    Manchester
    Vectra/Sunbeam/Nova
    why its got no electrical connectors its a mechanical system - i pitty the fool
    Aug 2004
    2.0 16v Vectra
    Quote Originally Posted by Vauxnova
    Im going by what was said earlier, will see when I take a look tomorow. thanks for the help.
    Jan 2002
    Bradford
    a Crotch Rocket
    Thats a point. I remember wires but they were for the heated seats.
    The tensioners are just mechanical as said.
    Mar 2004
    Stoke
    16v Nova,Astra SRi
    I think i read that they don't fire off unless they are subjected to 6G acceleration, i.e, in a crash.
    What exactly do they do?
    Tension the seatbelt?
    Jul 2000
    Manchester
    Vectra/Sunbeam/Nova
    yea - if you want to see them work lobbing them up in the air works well
