Results 1 to 7 of 7
Thread: Corsa Side Repeaters
    Feb 2005
    Hey, just bought some new side repeaters and was wondering what was the best way to remove the old ones? Do they pop off, slide or whatever
    Thanks in advance!
    Sep 2003
    Lincoln
    nova SR mk1 Xe
    push em to the one side and ping them out, if u look at the replacement repeaters there will be a little plastic bit on it designed to act as a spring to hold it in, look at the std ones in the wing and push to one side as if to compress the spring and shud pop out...dont woteva u do lose the loom in the wing after though
    Feb 2005
    thanks calidus, ive taken the std ones out now and i hav replaced em wiv my clear 1s (1 broke, gonna av go replace it in a minute)
    the new ones seem to fit realy loosely? it took sum effort to get the old ones out but the new ones slide out wiv my little finger, im worried they will fall out going over bumps etc... is this normal?
    EDIT- tried puttin the old ones back in, they fit loosely now as well
    MIGWeb User CraigG's Avatar
    Aug 2003
    Scotland
    Audi S4
    dont they have a sticky pad on the back face that sticks to the paintwork>
    i got corsa repeaters from vauxhall and they got a sticky foam on the back of it to hold it in place
    Feb 2005
    nah, no sticky pads on these 1s. ther r no sticky pads on the std either though...
    ne suggestions on what to use to stick it to the paint work with? bearing in mind i may wish to change them in future (no super glue )
    May 2004
    Northern Ireland
    1.2 8v corsa
    yes a little double sided stick tape will do ur job if put on right
    Sep 2003
    Lincoln
    nova SR mk1 Xe
    well mine pinged in and pinged out...i refitted clear corsa C ones to mine from vauxhall, dont even need new bulbs as there is a filament inside, bout 6quid for 2...or u can go borrow some off the forecourt
