1.4spi astra
hi i need to know where to get a bent chrome pipe to come off of the side pipe on the throttle body and connect up to an induction cone which will be behind the drivers front light ?
any one know where to get these things??
you can get aluminium flexi tube, think you can get it in halfords, or other car accesory shops. just get yourself a couple of jubilee clips to tighten it to the filter and injector pipe. if this is a mk3 astra i found a good way to bolt the airfilter to the car was to remove the old box filter, get yourself a suitably sized drainpipe bracket from B&Q etc. get a few self tapping sxrews and drill suitable sized holes where the air box was and screw the bracket in and away and use this to mount to the space where the airbox was.
Registered User
A garage that has a pipe bender could make you one out of exhaust pipe or for more cash stainless steel. I had one offered inc filter and pipework to take filter right behind drivers light for £120 fitted. Not stainless though. But still good price..
