Results 1 to 8 of 8
Thread: will they fit??
    Sep 2004
    Colchester, Essex
    Calibra LE 4x4 Turbo
    will they fit??
    i've seen some 17" alloys, i have a 1993 astra cesaro 5door, the stud fitment of the alloys is PCD: 4x100 and the offset: .........35-38......... and are size 215/45/17. will they fit??
    Apr 2004
    Ruislip, Middlesex
    Astra 1.8 SXi
    You might find the tyres are a little bit wide, depending on whether your car is lowered or not. I've got 17's on my Cav GSi, in a 4x100, ET35, and they don't rub or catch at all. Not quite sure what'll happen when I lower it next week though!
    It's supposed to be a challenge, that's why they call it a shortcut. If it was easy it'd just be "the way".
    Registered User Cathcart cav's Avatar
    Feb 2005
    Dunfermline(in fife)
    Cavy 1.8Glsi
    Well i have et38 i think. Cav lowered 60 all round. 205/40/17. No scrubbin what so ever. Put my hand up the arches and its close but no touch..
    Sep 2003
    Lincoln
    nova SR mk1 Xe
    my kahns will fit if u wanna buy em lol 17s too et45...
    Jan 2005
    West Lothian
    Cavalier V6
    they will rub inside the back arch
    MIGWeb User TurboCavGSI's Avatar
    Mar 2004
    Derbyshire
    Cavalier GSI Tu
    I wouldnt recommend it, Max i would go for is 7 x 17 et 42 with 205 40 17 tyres.
    You can't build a reputation on what you are going to do.
    Apr 2004
    Ruislip, Middlesex
    Astra 1.8 SXi
    I have a set of ET45 alloys, but when I tried them on my Car, I couldn't put the centre caps back on the fronts cos the driveshaft ends stuck out too much. Fit anything from ET35 to 42 and you should be fine.
    Mar 2004
    Derbyshire
    Cavalier GSI Tu
    Quote Originally Posted by GSi24v
    I had the same problem,i just shortened the thread.
