alloy wheels
will vauxhall astra sxi 16 inch fitt on a nova ? can i fit seventeens on a nova if i ca n how much work is involved thanks for your help
If the SXi wheels are 4 stud then yes. The look fantastic on Novas also.
17's on a Nova?? Bit too big, but they should fit with only minimal arch lip work if you select a compatible offset.
got 17s on my nova dnt scuff at all
