Results 1 to 15 of 15
Thread: Can I Refurbish My Alloy Wheels Myself?
    Oct 2004
    uk
    Nova gsi, Nova
    HI, Brought some 15" tigra alloys for me nova, but they've got quite alot of scraches on them where they've been droped on there face a few times & general kerb scraches, so ive looked into getting them refurbished, tryed wicked wheels & they want 65+vat per corner, not bad i spose for a pro service but i just can't justify it, not since they cost me £150 with 2 good goodyear tyres, only to find out now that one of them is flat, & on closer inspection has a nail in it! if it's as bad as it looks then ive got to buy 4 new tyres + refurbishment.
    so has anyone ever refurbished alloys themselves it must be posible to do this does anyone know the process?
    any ideas would be most appricated
    cheers
    matt
    MIGClub Member angryman's Avatar
    Mar 2004
    N W London
    2.0 16v Vectra SRi
    Feb 2005
    easy job just sand it smooth so u cant feel any scratches anymore then apply acid etch primer then some normal primer then some kind of silver paint or wateva finish you would like
    simple job done
    Feb 2005
    you may have to fill any deep scratches and sand it smooth
    Oct 2004
    uk
    Nova gsi, Nova
    would chemical metal be alright to use as filler? Got any tip on spraying lacquer, as when ive used it before it just goes misty?
    cheers
    Feb 2005
    just make sure when you spray lacquer you spray it in thin coats and build it up and make sure its not too hot or too cold when your spraying. after spraying polish it quite abit to create the nice shine.
    Mar 2004
    N W London
    2.0 16v Vectra SRi
    Quote Originally Posted by mboasty
    cheers
    Chemical metal will be fine
    Nov 2004
    Gloucestershire, UK
    Astra GTE 2.0L 8V
    Just used Chemical Metal myself. Seems fine.
    Oct 2004
    uk
    Nova gsi, Nova
    Take it that u just rub the whole wheel down with wet & dry, & not nothing to abbrasive like 80 grit?
    midands
    astra 888 (280/320)
    i used chemical metal after i rubbed the wheels down - used etch 1k primer - then sprayed with halfords paint - 2 years on there still looking good
    www.customgraphixs.co.ukclick to visit the site
    Mar 2004
    N W London
    2.0 16v Vectra SRi
    If the filler is raised quite a bit then start of with 80 grit locally carefully to get the filller near level with the surface. I then used 120 grit on the filler and wet 400 grit over the whole wheel(s)
    I then had a good look over the wheels to see if there were any funny bits. I filled these with normal P38 filler and went through the same process to the 400 grit.
    I then used warm water, tad of washing up liquid and 1200 grit (keep it wet) to get a smooth finish.
    I haven't rushed mine as I want as good as finish as possible, and as they are a spare set don't need them back on the car. Others doing this may be less impatient so skimp on the process a bit
    Apr 2002
    High Wycombe Looks@:
    The White Wonder
    Quote Originally Posted by st200 rich
    where'd ya get the etch primer from?
    Total Carlton (Carlton Forum)
    Oct 2004
    uk
    Nova gsi, Nova
    thanks for the advice most helpful cheers, i wont be rushing them as i dont need them on just yet & ive got alot of patience with things like that! thanks for the help mate
    matt
    Mar 2004
    N W London
    2.0 16v Vectra SRi
    matt
    If that's for me then keep an eye on my thread in the link earlier
    midands
    astra 888 (280/320)
    [QUOTE]where'd ya get the etch primer from
    HALFRAUDS
