How do you remove the astra mk3 gear knob?
Thanks Andy
Thanks Andy
Turbo Power is here!!!! And my god i LOVE IT!!!!!!!!!!!!
With brute force lol or chop it off.
I thought it was a screw in thing, that had some glue underneath the gear knob?
The standard knob is glued on,aftermarket ones generally use a grub screw to secure them.
You can take the whole gear stick off and saok the knob in hot water to loosen the glue,look under the gaitor for the securing pin,at the bottom of the stick.
hacksaw! well thats wot i used anyway! on the phase 1 astra, the knob just pulls off, and then you're left with a green/yellow stub - cut this off. the phase 2 knobs don't pull off, you need to cut it down bit by bit until you get to the metal (not going throught, mind!) if you do this, make sure you cover up the plastic around the base of the gear stick, as the rubber and plastic "dust" is a bitch to remove. hope that helps![]()
Vauxhall Astra Mk3 Owner's Club
i removed my phase two by pulling it off they are glued on.
replaced mine with a irmscher ally one no need to cut the stick down.
Phase 2 ones/Vectra ones just twist off.
They only push fit, but are very tight, so you need a bit of muscle to shift them.
a HACKSAW?! Nah get your self a grinder. have some fun while doing the job too!Originally Posted by eldridge1849
It shows how old mine must have been, i removed it quite easily just by pulling and twisting.I have an aftermarket one to fit but i dunno how its spose to fit as the gear lever is covered in all plastic parts for the lift up reverse mechanism.
hack off the green plastic bit, then the later MK3 Astra/Vectra knob will push on.Originally Posted by LongLiveTheNova
Better still, get the lift up sleeve to match as it fits the knob better.
