Results 1 to 20 of 20
Thread: Rear Headrests
    Dec 2004
    Hampshire
    Focus mk5/Astra mk5
    Rear Headrests
    is there a way of putting rear headrests into a mk3 astra ls lreg (blue int)
    or do i need new seats
    Sep 2004
    Kidderminster
    Vectra v6
    Why you want them? Will block your vision
    And no you cant.
    Nothing to put the supports onto.
    Dec 2004
    Hampshire
    Focus mk5/Astra mk5
    ok m8 nps
    thx for that
    May 2004
    Woking/Leicester
    1.6 16v Astra mk3
    i think astra_dan did it in his if im right ... or astradan. same thing.
    Apr 2002
    Liverpool
    Fettled Octy vRS.
    I just slid mine between the parcel shelf and the rear seat and secured them. Look ok.
    May 2004
    Woking/Leicester
    1.6 16v Astra mk3
    "Look okay .." ... ?
    But do they actually work, ie: are they secured strong enough to stop a apssengers head from flying backwards?
    Mar 2003
    Stafford
    Cav V6 & Nova GT'XE
    TBH i would have thought you would be able to. My 1990 Nova GTE has holes in the frame of the seat for the headrest holder things. Just feel across the top of the back seat and you should feel some holes approx. 1.5" wide and headrest width apart.
    Oct 2004
    Aberdeenshire
    ASTRA SRI 170
    Mar 2003
    Stafford
    Cav V6 & Nova GT'XE
    Just grabbed these pics of the nova rear bench. We have stripped the seat for a re-trim but you can see the 2 larger holes are where the bracket holder things would go:
    And they are exactly the right width for a headrest:
    Apr 2002
    Liverpool
    Fettled Octy vRS.
    Quote Originally Posted by EasyRider
    Yeah, but they dont move. Plus they make the interior look a bit smarter.
    Mar 2003
    Stafford
    Cav V6 & Nova GT'XE
    Quote Originally Posted by AndrewM
    I did that at first, but they move left and right and look a mess. They just don't look right
    Apr 2002
    Liverpool
    Fettled Octy vRS.
    I might have a nose and see if theres any holes in the rear bench.
    Mar 2003
    Stafford
    Cav V6 & Nova GT'XE
    Just have a prod and push across the top. I'm sure that yours will have if my Nova has them...
    Apr 2002
    Liverpool
    Fettled Octy vRS.
    I take it yours was a GTE, is the rear bench on yours one piece? I heard something that only the split rear seats have the holes..
    Mar 2003
    Stafford
    Cav V6 & Nova GT'XE
    Yes it is a GTE and it does have 60/40 split rear..
    Apr 2002
    Liverpool
    Fettled Octy vRS.
    Ah, mines a one piece thing, Ill check anyway, cheers
    Aug 2004
    Edinburgh
    Megane Coupe 2.0 16v
    Whils't the top holes for the plastic guides are there, the "U" shaped retainer to hold the bottom end of the guides ISN'T there, even the Vauxhall TIS tells you it can't be done, it says you have to replace the seat back.
    Sep 2003
    Lincoln
    nova SR mk1 Xe
    all of my novas got the rear headrest treatment lol the gte, the sr the other sr and the SR lookalike, as a general rule i think its only split folding rear seats that take them, my corsa now has a brace of 3 in the back looks pretty classy and they do work!!! also if u just slot in ur headrests between parcel shelf n brake harshly sometimes they come out
    Jun 2001
    Essex
    Mk3 Astra Saloon
    Some astra mk3's had runners in the rear seats, others didn't......!
    Click to view Polaris
    Apr 2005
    Glasgow-ish
    1997 Astra F 1.6 LS
    just on this topic, does any1 know if a corsa B (pre V grille model) will have the holes for the rear head rests?? just wondering so I can get a corsa with a rear seat that will take them.
    also have a mk3 97 R 1.6 LS astra, with 60/40 split seats, will it have the holes for RHRs??
    cheers.
