Results 1 to 21 of 21
Thread: blue sidelight bulbs
    Jul 2003
    south yorkshire
    sensibly
    ok got sum blue sidelight bulbs for the astra lil present
    an i quite like em when they lit up
    prob is when i turn dipped beam on they stay on so i have a blue tinge to my lights which is illegal
    any1 else done sumthing so lights work and are just white to stop this??
    drive like u stole it
    Mar 2001
    Torquay
    LC 20VT
    Re: blue sidelight bulbs
    Quote Originally Posted by ASTRA DAVE
    yeah,i used white led bulbs
    Jul 2003
    south yorkshire
    sensibly
    thanks lee that didnt really help me, lol if they jus hurried up wid angel eye lights i wud be fine
    now seriously any1 done anything to these to make em work fitted them to a seperate switch or something
    Apr 2004
    Derby
    GSi+cbr6rr+gsxr+st24
    Quote Originally Posted by LEE69
    Me too...
    Astra GSi mk3, ST24, CBR600RR Movistar, RS250 and a GSX-R 750 k3 148bhp...
    Need more toys...
    Jul 2003
    south yorkshire
    sensibly
    ok were missing the point now aint we i dont have white i have blue
    and im asking for advice from people who have got blue or had BLUE
    not white not normal bulbs
    BLUE
    lol thank u please ,
    i got flu too thats sucks at xmas dont it
    Mar 2001
    Torquay
    LC 20VT
    Put a switch in line,showing blue is illegal,you'll be fined a guy down here did.
    Jul 2003
    south yorkshire
    sensibly
    cheers lee jus i need to know what to do ive been told by my old man not to drill another hole into the back of the headlight as it may not pass the mot if i do and if condensation or water gets in it messes the reflector up then i need new headlights
    also if i put a new switch for my sidelights so wen dipped beam on the sidelights turned off wud this pass an mot as the sidelights wud operate off a diff switch
    the only other idea i had was to drill the indicators an put a switch to them for there as there no reflector to mess up in the indicator
    Jul 2004
    oxford
    turbo astra mk3
    well my argument is if red blue lights r illegal on front then y do cars have headlights with the blue tint to them also white is illegal at back so why r the number plate and reverse white also why r indicators orange then
    Mar 2001
    Torquay
    LC 20VT
    yeah seen that before generally with strobes though.
    Best idea i think,in the indicators.
    Jul 2003
    south yorkshire
    sensibly
    guess so then it has to be in tinticators i know what u mean bout the blue tinted lights seen em behind me b4
    Jul 2002
    Northampton
    astra GSI Turbo
    fit a relay so that it switches on when the dip beam is on. this will then switch the blue off. also it will fail the MOT with blue in . put a fuse in the feed to the relay so you just change the blue over to white and pull the fuse at mot time
    Jul 2003
    south yorkshire
    sensibly
    write lets see if i got this right
    if i put a relay in while the blue leds in when i turn to dipped beam the sidelights will turn off so that the headlight jus appears white and when im on sidelights they will appear blue
    then at mot time i put the normal sidelight blubs back in pull the fuse from the relay ive made so that the sidelights will come on with main beam an everything will function as normal
    Dec 2004
    either that or you could get rid of the connections to the side light bulbs and just wire your own powersupply to them, using a switch wired into the car. When mot time comes, just fit back the original connections. less effort, but probably in the long run the other way is better.
    Dec 2004
    norfolk
    95 aero
    wood'nt worry abot it if you like the blue builbs then leave them in, ive been running blue sidelight & headlight builbs for around three years in my cars now & never had a problem been pulled over loads of times by cops for checks & stuff thay dont seem to care
    once forgot to take them out for a mot & it passed fine.
    Moderator Nobbie's Avatar
    Hemel Hempstead
    with blue lights
    I just used brighter, slightly higer wattage, white headlight, that then makes them look like xenon bulbs, i got no problems, apart from when i drove home with only sidelights, and fogs on, but then again, it was asking for it!
    Sep 2000
    Manchester
    XE Corsa
    I've got blue led side lights on the gf's 206.
    They are seperate from the headlight casing so show up all the time.
    I even drive with just sidelights on when it's not dark.
    Seen a few New fiestas driving round Rochdale with the same.
    I've never been pulled with them before.
    The 206 will show the blue a lot more then the Astra will ever.
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Quote Originally Posted by Nobbie
    ..apart from when i drove home with only sidelights, and fogs on!
    chav chav chav
    MIGWeb User GSiJane's Avatar
    Feb 2003
    Hemel Hempstead
    Astra coupe tur
    Cough, Flamer Kit, Cough!
    BITE ME I'M A VETERINARY NURSE!!!!!!
    Awaiting Email Confirmation
    Nov 2000
    St. Asaph, N. Wales
    Nova, Passat
    how did the copper spot the fogs??? they are in the headlights on callys!!
    Nov 2000
    West Yorkshire
    Astra Mk4 BwarpTish
    Quote Originally Posted by GSiJane
    chavs dont drive cars with enough overfuel to have a flamer kit so //finger
    fogs are generally the first mod on a small engined car however.
    chav chav chav
    ps. got fix your ftp
    Jul 2003
    south yorkshire
    sensibly
    thanks for all the advice i mounted them in the indicators in the end look nice wen parked up at shows jus summit diff
