Results 1 to 18 of 18
Thread: Momo boss kit... Cav turbo
    May 2001
    South Wales
    Nippy Cav Turbo
    Does anyone know if this momo styled boss kit will fit an airbagged cav turbo L reg '94 steering column?
    I hear the non airbagged column differs than the airbagged column concerning the splines.
    here for advert on this item....
    cheers adam
    Jun 2000
    Hampshire, UK
    Vectra SRi
    Re: Momo boss kit... Cav turbo
    the splines are indentical from the airbag to non airbag columns
    its the wheel and the black airbag position ring that are different, you need to disconnect the battery for over 1 min, then remove the airbag and then remove the steering wheel in the normal manner then behind the wheel is a movabel black plastic ring that is around the column, you need to unplug this and then remove it from the viehicle
    cut and join the two yellow wires together and one of the brown wires goes to the metal sprung contact at the top of the column for the horn push.
    once this is done the column is identical to the non airbag model and you can then use the geniune momo hub to mount your momo wheel.
    May 2001
    South Wales
    Nippy Cav Turbo
    cheers matey for in-depth info i actually undertsand! one thing though.... this aint a genuine momo boss does that matter? being like 25 bucks cheaper?
    cheers adam
    Jun 2000
    Hampshire, UK
    Vectra SRi
    does it fit the wheel properly that you have?
    does it have a wire in it for the horn earth?
    do you have any better pics
    what i would advise is that you remove the airbag and wheel, then remove the ring and unplug it, then test fit the boss and see if it fits, but attach the wheel to the boss first so you can manouvre the boss on the column.
    if it fits any other vauxhall and it fits the momo wheel you have then you should be ok but you need to do the wiring as well.
    if you dont join the two yellow wires together you will get the airbag light come on and thats a dealer reset.
    also if you remove the airbag without disconnecting the battery you will get the airbag light on
    May 2001
    South Wales
    Nippy Cav Turbo
    the guy selling said it fits the non airbagged one but not sure about the baged one as stated on enay on link reply.... u know u say if i dont join the wires together and have a dealer rest then.... if by chance i forgot to can i do it ata later date?
    Jun 2000
    Hampshire, UK
    Vectra SRi
    you could do it yes but the airbag light will be on all the time your driving which would annoy me intensly
    May 2001
    South Wales
    Nippy Cav Turbo
    abit like the ole tranny light init lmao
    k cheers matey ill buy it now and seek any mares i find after ripping column off and wheel etc..cause i know once again i prob wont be able to get this steering wheel off! but its worth it to fit me momo thats gathering dust
    cheers adam
    p.s. merry xmas bud
    Jun 2000
    Hampshire, UK
    Vectra SRi
    and you
    Sep 2004
    Nottingham M1 J26
    Cars. Loves: Dirty sluts
    Question Re: Momo boss kit... Cav turbo
    Quote Originally Posted by Tom Williams
    Hi there i am about to remove a Calibra airbag - just how do i do this? I presume it will lever out to reveal the normal steering wheel bolt as found in non-airbag calibras?
    OK let's be honest - is it going to explode on me?!
    Jun 2000
    Hampshire, UK
    Vectra SRi
    you need to disconnect the battery for a minute or more, then in the back of the steering wheel are two allen key bolts facing the driver holding the airbag assembly in from the back. undo these two and them pull bag forward and unplug the airbag
    but if you dont disconnect the battery it will/or may go off.
    May 2001
    South Wales
    Nippy Cav Turbo
    do u realise how hard it is to undo them allen key bolts with the bloody steering wheel still attached to column and attached to car? lmao
    Jun 2000
    Hampshire, UK
    Vectra SRi
    yes as i have done it before, you need to turn the wheel and then insert allen key and hold end of allen key with pliers. then get person #2 to pull the hweel the right way to undo the two allen key bolts whilst remaining grip on the pliers
    RDS
    RDS is offline
    Jun 2001
    Plymouth
    Veccy 3.0 24v Diesel
    Believe me you don't want the airbag to go off, its a **** your self moment when it does go.
    Sir, please step away from the car
    Jun 2000
    Hampshire, UK
    Vectra SRi
    didnt you and mike set on off rob?
    May 2001
    South Wales
    Nippy Cav Turbo
    lmao aint that so true..but i just ripped the column out
    May 2001
    South Wales
    Nippy Cav Turbo
    Quote Originally Posted by RDS
    why? lmao
    Sep 2004
    Nottingham M1 J26
    Does anyone know which way round the boss goes in relation to the car?
    There's a big wedge on the back of it (i presume to cancel the indicators) and there's also a label saying "ToP"... but these are at odd angles!
    Bloody italians
    The wheel is quite pretty though
    May 2001
    South Wales
    Nippy Cav Turbo
    what steering wheel is it mate? not momo?
