Results 1 to 17 of 17
Thread: Alloys
    Oct 2004
    Powys, Mid-Wales.
    Impreza Type Ra
    Alloys
    I've been offered some TSW Reflex alloys off a Renault Megane, will they fit on my cali properly? I know they are the same PCD but are they the same ET?
    Cheers!
    lee may
    Guest
    Re: Alloys
    Renaults are normaly ET35
    Oct 2004
    Powys, Mid-Wales.
    Impreza Type Ra
    Re: Alloys
    will they be ok on my cali then since i know it's about et 49 isnt it?
    lee may
    Guest
    Re: Alloys
    Depends what size they are,
    Upto 17's will fit but it will drive horible and tramline (Follow ruts and marks in the road)
    Also will wear wheel bearings quicker as the centre of the wheel is further out than standard
    Oct 2004
    Powys, Mid-Wales.
    Impreza Type Ra
    Re: Alloys
    crap :/ it thought you might say that, guess i'll scrap the idea of some ebay 17" TSW reflex's what ET range should I be looking for?
    EDIT: Are there any sites that list the ET's to save me keep asking on my quest to find the right alloy
    Nov 2004
    belfast. N.I
    1.4 8v Corsa 5 door
    Re: Alloys
    u shud be lookin really only for et 45 or et 49 cus if u go any different and lower ur car it will just scrub ur arches no stop and where out ur bearings like lee may said.. hope thats any help to ya
    lee may
    Guest
    Re: Alloys
    As above
    Et45-ET49 and upto 7 1/2" wide max with about a 215 or 205 40 or 45 tyre
    Nov 2004
    belfast. N.I
    1.4 8v Corsa 5 door
    Re: Alloys
    there ya go remus that shud solve ur problem..
    Nov 2003
    Herts
    e46 M3
    Re: Alloys
    sorry for the hijack but Lee du know if et 45 18's with 235/30 tyres will go on a cav?
    lee may
    Guest
    Re: Alloys
    They should just fit on the rears but 225's rub the arches on the front if you are turning and hit a bump.
    I have removed about an inch of the platic arch and most of the arch lip and they are ok now (Just) on the front.
    Nov 2003
    Herts
    e46 M3
    Re: Alloys
    cheers - so I guess lowering it on them would be stupid! Presumably I could take it somewhere and get them to sort the arches tho? So beyond a bit of rolling they should be fine? Just keep thinking of the handling benefits of 235 wide rubber hehe
    Oct 2004
    Powys, Mid-Wales.
    Impreza Type Ra
    Re: Alloys
    ok i'm thinking about buying some bk 7 spokes, but I don't understand what the JJ bit of this is?
    17x7JJ & +35
    so they are 17" diameter, 7" wide and have an ET of 35 but the guy can't find anything to do with the pcd fitment :/ he said they are multi fitment and have 10 stud holes, do you reckon they will fit?
    lee may
    Guest
    Re: Alloys
    Yes they are as you said.
    Even though they are multi fit they are drilled for 2 PCD's only so you need to find out what.
    Oct 2004
    Powys, Mid-Wales.
    Impreza Type Ra
    Re: Alloys
    ahh good stuff, do you know what does the JJ bit means? I'll email him again to ask what car they were fitted too (2nd time i've asked him now).
    EDIT: Nvm the same guy sells 10mm spacers too
    lee may
    Guest
    Re: Alloys
    Some wheel companys just say J. No idea why.
    7J is 7" etc
    Oct 2004
    Powys, Mid-Wales.
    Impreza Type Ra
    Re: Alloys
    thanks again lee!
    Oct 2004
    Powys, Mid-Wales.
    Impreza Type Ra
    Didn't want to make another thread so i'll post it here:
    Does anyone know if I can put 5x108 alloys on calibra turbo 5x110 ?
