will an l reg astra gsi grille fit nicely onto a phase2 p reg astra?
also, it has light washers on it. how easy will this be to set up on a car without the washer jets?
Astra Coupe 2.2 16v
ah bummer, i thought you were gonna ask what MIG stands for, or what a coscast head is.
lol
Astra Coupe 2.2 16v
Afaik the headlight shapes are slightly different between pahse 1 and 2 so it won't be a perfect fit but can probably be made to fit.
Phase 1 grill on phase 2 will leave big gaps along the side of the headlights.
yer get phase one lights aswell, will fit fine then.
Originally Posted by 0ddball
Or are Vectra door handles a straight swap on a Mk3 astra
It'll go on and from a distance look fine, up close though it doesn't quite sit properly round the lights due to the phase 2 being more slanted.
As for the washer jets, forget it, its far too much hassle for such little gain. You need to obtain the bottle, locate it in the wing, wire and plumb it up etc.
Just buy a new grill and it comes without the jets, with no hole where they should be either.
I got a new gsi grill which i bought new and never fitted as you saw i decided to de-badge v grill as gsi wouldn't fit, it's brand new never been used or sprayed, no washer jet cut outs but recesses behind if you want to fit em, yours for £30 incl p&p if you want it.
