Cellulose + 2-Pack lacquer (clear coat) ?
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 26
Thread: Cellulose + 2-Pack lacquer (clear coat) ?
    Aug 2004
    MOON
    TANK
    Thumbs up Cellulose + 2-Pack lacquer (clear coat) ?
    What I need to know is after I respray my car with (Solid Black) Cellulose paint can I let the Celly dry (about 3 days) before I coat it with a 2-Pack lacquer (clear coat) ? and do I need to compound the Celly to a shine before I spray with 2-Pack lacquer (clear coat) ?
    Would the Celly paint react with a 2-Pack lacquer (clear coat) ? and would this give me the good deep high gloss finish that Im after ?
    Thanks for your help..
    MK3 astra only forum www.mk3oc.com
    Dec 2001
    Chelmsford, Essex,
    Astra1.8, Zaf1.8/1.9CDTI
    Re: Cellulose + 2-Pack lacquer (clear coat) ?
    use 2 pack base coat, and Celly/Poly Laquer, and you'll live longer.
    Aug 2004
    MOON
    TANK
    Thread Starter
    Quote Originally Posted by Mark T
    Well thank you for that but could you answer my questions?
    p.s. How the hell is using 2pac base and celly clear rather than 2pac clear and celly base make me live longer?
  5. Remove Advertisements
    Dec 2001
    Chelmsford, Essex,
    2 pack laquer Hardener is higly toxic. Air line respirator only.
    2 pack base, and any celly can be done with a Charcoal respirator.
    Celly laquer is easier to polish up to a high shine.
  7. #5
    Mar 2004
    Nottingham
    Ventora & Yanks
    If its celly it doesn't need a lacquer. You polish the paint direct. Some people say that polishing the paint not the lacquer gives a much deeper shine than polishing lacquer which only gives a superficial shine. I've seen cars done in celly with no clear which look like glass, its a superb effect when you get it right.
    I would be dubious about cellose lacquer over a 2 pack base due to cellulose being a sod for reacting with other paint types.
    TBH I'd probably go for a 2 pack base and clear as it will last longer if its a daily driver. Celly is more chip prone, and you have to maintain it, good quality sealer wax or it will oxidise quickly.
    I got a respirator recently so I can do 2 pack, celulose is really old tech now and a lot of places don't do it any more, all the advances are in "compliant" paints now. Some colours can't be matched in celly, etc. etc.
    Your choice.
  8. #6
    Mar 2004
    Nottingham
    Ventora & Yanks
    oh and, to answer your question, if you clear over a celly base don't buff it to a shine first.
  9. #7
    Aug 2004
    MOON
    TANK
    Thread Starter
    Thanks alistairk + Mark T
    So are you saying 2-pack clear over a celly base is not a good idear ? (reacting)
    Why Im using a celly base is: I have 4L of black to be used up and I hate waste . I know celly is not the toughest so I thought 2-4 coats of 2-pack clear on top would strength it up ? and give a good shine with out much compounding work..
    Also I thought 2-Pack base had Hardener and was as higly toxic as the 2-pack lacquer is ?
    Can someone give more info on this??
    Jimbo
  10. #8
    Oct 2001
    Herts
    Grale, Mustang, 535i
    2-pack base coat doesn't have any hardener in, just thinner.
    Mike
  11. #9
    Aug 2004
    MOON
    TANK
    Thread Starter
    Quote Originally Posted by Mike007
    Mike
    Ahh right ...Thanks
    Sorry for all the questions peeps ........ Thanks for the help..
  12. #10
    Mar 2004
    Nottingham
    Ventora & Yanks
    2 pack clear over celulose should be OK, celulose over 2 pack is asking for trouble (IMHO) as celulose has a habit of reacting with other paint types as bases.
    At also strikes me as the wrong way around. You want the 2 pack on top as its the more durable finish.
    I'm not a 2 pack expert, but I thought I'd seen hardeners for 2 pack bases? Whats with that Mike? I'm presuming a catalyst to speed up curing in "production" environments?
    Celly is dissed as being a poor long term finish, but I knew a guy with a black Austin Somerset built in 1953 and it still had its original factory black celulose paint on it last time I saw it (about 1992, he sold it after that). It was still shiny, although it was polishing thin in a couple of places.
    Put plenty on, buff a good shine in it, hand glaze it for the first 2 months or so then get a quality polymer wax and sealer on it (Meguairs NXT perhaps?) and keep it waxed well and it should shine deep and rich for as long as you own the car.
    Since you want to use up the celly, its the way I'd go.
  13. #11
    Oct 2001
    Herts
    Quote Originally Posted by alistairk
    You can use a small amont of hardener in 2-pack base coat (about 10% RFU) to improve durability - it doesn't cross link like a 2-pack direct gloss or laquer but it does improve durability, especially stone chipping. It may be that some not-so-good paint recommend it as std to compensate for poor paint, I'm not too sure.
    If you are going to use a 2-pack laquer I see no point in risking reaction or anything else - you may as well just use a 2-pack base coat. And buy the most expensive laquer that you can afford, as it is the laquer that will contain UV absorbers and things that wil stop (or at least slow down) your paint fading.
    Mike
  14. #12
    Mar 2004
    Nottingham
    Ventora & Yanks
    Cheers Mike, that makes sense.
  15. #13
    Jan 2002
    south
    astra
    hello all
    i started spaying around 2 years ago and still consider myself very much an amateur at it despite some realy gopod finishes. I dont know how experianced you are mate but when i was researching like you arer i found there was so much information i almost went crazy. in my opinion the most important things are a dust free enviorment with a few heaters to raise the temp slightly + practice. the real answere to getting an excelant shine is in the ability of your spraying. Sure the right tools for the job help a great deal but i guess i trying to say if you mess up just the slightest it can rewine the whole thing and when you spend all that tyime on preperation it can be a real pain in the arse.
    I know this doesnt realy answere your question but just thoguht id add. hope this helps anyway. i spray with celly and never go near two pack because of the health risk and cost of air masks etc. so if i can be of any help with advice on the basic celly proces let me know mate - i needed all the help i could get without the jargon!
    have fun,
    regards,
    Neal
  16. #14
    May 2004
    Birmingham
    Vectra saloon 2.2sri
    nice post gettingthere spot on
    dust free environment / tiled floors and walls with heaters and vacuums
    as for cellulose, I would suggest using that unless u have the perfect working conditions and a 5k spray gun and compressor
    with cellulose u can build up the coats and even if the end product is dull u can using cutting compound / t cut and resin polish to bring out the shine, loads of elbow grease and patience will make the finish look professional, I use a 50 gravity gun and 100 compressor, I spray my car outside sometimes when it is hot / sun shining and no wind
    with 2 pac u cant use t cut as the laquer gives it the shine and t cut will just remove the laquer leaving it duller
  17. #15
    Jan 2002
    south
    astra
    Also spot on, sounds like me lmao :
    "with cellulose u can build up the coats and even if the end product is dull u can using cutting compound / t cut and resin polish to bring out the shine, loads of elbow grease and patience will make the finish look professional, I use a 50 gravity gun and 100 compressor, I spray my car outside sometimes when it is hot / sun shining and no wind"
  18. #16
    Mar 2004
    Nottingham
    Ventora & Yanks
    you can cut & polish 2 pack clear.
    Although for the in-the-garage/on-the-drive spraying operations celly still does the trick. Dries off quicker so you get less dust in it.
  19. #17
    Oct 2001
    Herts
    Quote Originally Posted by ephid0r
    T-cut (or any other cutting compound) has exactly the same effect on Celly as with 2-pack - the abrasive removes the top layer of paint, reducing orange peel and usually improving gloss.
    Mike
  20. #18
    Aug 2004
    MOON
    TANK
    Thread Starter
    WOW thanks for the info peeps
    Since this is my first respray and Im not going to have the car for that long im going with the Celly base and NO laquer top coat...This is just a big learning experience for me to see If I can mod and spray a car ..its great fun fooking about with body filler /paint and GRP to create something never seen before..
    I will be spraying the shell this weekend and the doors etc next week...Im takeing pics of each process along the way and will post them up when finished..
    Im doing some custom panal /bumper and lighting mods to my mk3 some of which have never been done /seen before so watch this space. (no tacky stuff garantee)
    Jimbo out
  21. #19
    Oct 2001
    Herts
    Make sure you get direct gloss not base coat as base coat will give a matt finish as it is designed to have a laquer on top (I assume celly is the same as 2-pack in that regard).
    Mike
  22. #20
    Mar 2004
    Nottingham
    Ventora & Yanks
    Its usually only the metallic celly which comes as a basecoat needing lacquer. Solid colours are usually/always top coat.
    Looking forward to the pictures Jimbo Good luck. Have fun with it. Its not as hard or daunting as people make it sound talking about it. A good even pass with your spray gun, getting a good even pattern from the spray gun, and getting the prep good. Those are the three things to remember and with those three taken care of it pretty much sorts itself. Then just a good buff up and the job's a good 'un.
  23. #21
    Nov 2002
    fghjuf
    Quote Originally Posted by jimbo750
    Jimbo out
    You really wanna paint ALL outwardly visable panels at the same time,this weeks paint you mix up may be a slightly different colour than next weeks.
    Plus,one thing no-one has mentioned is make sure you thouroly degrease the surface before you paint,any grease spots and the paint wont stick and you end up with little round dimples with no paint in.
    Dave
  24. #22
    Aug 2004
    MOON
    TANK
    Thread Starter
    Big thanks to you lot for all the help and advice and them that sent pm's I owe you all a pint...
    The shell is done WWWOOOHHHOOO the solid celly has came up very nice and I haven't compounded it yet..
    here is a pic of the front panal with the side repeaters removed and them two horrid lines that run down the side of the car smoothed off how it should be....
  25. #23
    Oct 2001
    Herts
    Good job mate - glad it looks good. You'll have to get some pics up when it's all complete.
    Mike
  26. #24
    Mar 2004
    Nottingham
    Ventora & Yanks
    Looking good
  27. #25
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    mate thats looking quality- bet you are well pleased. Is that solid black? I am doing the very same thing in the next week- going to buy all the paint thursday and start at weekend. Im doing the doors/bonnet/taligate seperately off the car and that pic has inspired me cuz I was starting think it will look pants. Nice one matey
