calibra leather into an astra mk3?
Results 1 to 18 of 18
Thread: calibra leather into an astra mk3?
    Jul 2003
    solihull, birmingham
    st tdci, saff cossie
    i've heard people have done this and was wondering how hard it is to fit. A few people have said that the front seats will go in fairly easily. Do they need any modding to fit in, do they rub on the door cards, etc.
    Will the back seats fit in if modded ?
    any help or info would be greatly appreciated
    Cheerz
    MIGWeb User Scott G's Avatar
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    Re: calibra leather into an astra mk3?
    dave Dickson just did this.
    front seats are a straight swop and will take 2 minutes.
    Backs wont fit but Dave retrimmed his original seats with the leather, dunno how hard it was but im sure he will post here later on tonight.
    My ex Mk3 Astra - My Corsa Sport - Join MIG Club ONLINE Here!
    "A wise man know everything, a clever man knows everyone"
    May 2001
    South of France
    vectra sri v6
    Quote Originally Posted by Scott G
    ...Backs wont fit but Dave retrimmed his original seats with the leather, dunno how hard it was but im sure he will post here later on tonight.
    No I didnt!
    As said, the fronts are a straight swap. 4x 13mm bolts hold each seat subframe into the car, just swap the whole lot, including subframe. Everything lines up perfectly and the seats dont catch anywhere.
    The rears took a bit of persuasion. I looked at using the leather to re-trim the std ones, but it looks like a hassle so I just made the Calibra ones fit. The bottom section fits down nicely. The seatbelts wont come up through the holes in it, just up the back of it like in the astra, which is fine. Its just wedged in place, not clamped down like it was originally as the brackets dont even nearly line up.
    The back sections are slightly different widths though so take a bit of hammer-work. The centre support at the 60/40 split is in the wrong place so i hammered it flat, out the way. With a bit of work, the seats then bolted into the std mounts. they are maybe 1 - 1.5 inches too wide, but with an effort they will fit. I just left them as is, and one day when i can be assed I will weld the Calibra centre-mount to the astra floor, but so far it hasnt needed it. the seats are rock-solid without it.
    The bit where they latch at the top doesnt quite line up, but bending the steel loop downwards a bit and enlarging its mounting hole and using a big washer so it can mount maybe 1cm further out allows the seats to latch as normal so they can still be folded flat.
    The basic shape of the back section is slightly different so leaves a wee gap either side at the wheel-arch, which I covered with black acoustic cloth to hide. Looks fine.
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    You told me you retrimmed you gimp!
    May 2001
    South of France
    vectra sri v6
    pics....
    Excuse the mess in the pass footwell
    They looks the nuts, Im dead chuffed with them. Just need to get some wee cover things for the old bits where the sets used to hinge from and Im done!
    Also, i found that my GSi already had the wiring looms in place for the front seats to be heated. The sawitch connections were under the cetre console near the hand-brake. There were 2 blank panels where the switches go next the hand-brake lever.
    The seat-ends of the loom were under the carpet just where the two halves join, tucked away under the main sections of car loom under each seat.
    Just plug the seats in. get some switches, slam them into the centre-console and thats it!
    Jul 2003
    m8, that looks fu**ing mint
    can you tell me what door cards and quarter cards they are, are they custom ??
    also, what model calibra are they out of, do you know if v6 leather is a different style to 16v, do you know if turbo interior would fit....sorry for all the questions
    Cheerz m8
    Mar 2001
    Torquay
    LC 20VT
    yeah that looks very smart indeed.
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    Quote Originally Posted by 6-speed GSI
    Cheerz m8
    Since Daves offline Ill answer on his behalf.
    The door cards are GSI cards retrimmed in black suede and look superb.
    The leather is out of a V6 and all the leather will be the same.
    And yes Lee, it does look awesome!
    Sep 2001
    Glasgow Area-ish
    EVO VI & GTE 16
    the turbo has a bulge in the passenger footwell so the seat frames are different iirc
    Never get an EGG credit card they do nothing to protect you if your card is subject to Fraud!!!!!!!!!!!!!!!!!!!
    Moderator Nobbie's Avatar
    Hemel Hempstead
    with blue lights
    Does anyone know if the wiring is present in a 92/93 Mk3, iirc Davids is a later one.
    Mar 2001
    Torquay
    LC 20VT
    Quote Originally Posted by Nobbie
    yeah,the wiring is in mine, 'J' 92.
    May 2001
    57.37810N 2.08020W
    Honda Civic Typ
    Daves is a K.
    Apr 2004
    This has given me thought about my own seats, they are in fine condition but as Im an upholsterer, I might re-trim my seats in leather in the new year.
    MIGWeb User GSiJane's Avatar
    Feb 2003
    Hemel Hempstead
    Astra coupe tur
    Double Post!
    BITE ME I'M A VETERINARY NURSE!!!!!!
    Feb 2003
    Hemel Hempstead
    Astra coupe tur
    Mmmm, cream or black? in a black Gsi, Hmm
    Eastern Regional Coordinator Spinbitch's Avatar
    Sep 2003
    Colchester, Essex
    MK3 Astra & Dis
    hmmm, tempted with the idea of black cali leather in my astra after i turn it into a GSi rep.
    Chris
    AL
    AL is offline
    Dec 2004
    Birmingham
    Corsa D 1.7 CDTi
    Jeez, that leather does look good! Personally i think i'd make up new bracket's/catches so that it was all still functional - or just re-trim....
    How much for a Cally interior, roughly?
    Team Vauxsport - TOTB Team Manager
    Sep 2003
    Harborne, Bham
    Astra Coupe 2.2
    Sorry tom ressurect this post. But how id the rear seats fit? Are they just 'placed' threre? or have they been fixed in properly??
    Reason Im asking is cos Im thinking of doing something similar and just need afew ideas on how to get the rear seats into my astra
    See here:
    http://www.migweb.co.uk/forums/showt...62#post2010362
    Astra Coupe 2.2 16v
