Results 1 to 10 of 10
Thread: mk3 (1992, K reg) astra door handles, ideas needed
    May 2004
    eDINBURGH
    1992 1.4i 8v astra
    would like to change stanfard, sun bleached handles for something different.
    My skills are not that great so ideally a simple job is what im after, I was told daewoo handles were a straight swap, but ive also heard that you have to cut into the door replace back plates, linkages etc..
    anyway, any ideas & pics of any mk3 handle conversions greatly appreciated.
    many thanks in advance
    tragushardie@hotmail.com
    May 2002
    s/e Kent
    i dare not say !!!
    Re: mk3 (1992, K reg) astra door handles, ideas needed
    Why not just take them out,rub them smooth,and color code them your self ,probly easier than fitting daewoo ones
    Jul 2004
    notts
    astra gsi
    why not just get the door handles out of the earlier shape vectra,they is a straight fit
    plus a bit better looking-j
    May 2004
    eDINBURGH
    1992 1.4i 8v astra
    the ones from the vectra, what year is that up to?
    May 2004
    eDINBURGH
    1992 1.4i 8v astra
    reason being is that car is away on 16th for a full respray
    Feb 2004
    Bournemouth
    Vivas,Capri,P5,900T
    so get em resprayed at the same time - just sand em down a bit
    In UR BITCH MEKKIN NOO DOODZ
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    Handles from a 96> Astra/Corsa are better than Vectra ones, as you can use the lock barrel.
    Vectra Locks are like Cav ones.
    The only benefit of Vectra ones, is that you can get ready painted ones, which are smoother.
    You still need a late Corsa/Astra back plate for the lock.
    May 2004
    eDINBURGH
    1992 1.4i 8v astra
    is that all thats required for the vectra handles (the back plate) and everything else just connects up ok?
    what year is the early vectras, i.e what reg can i get them from?
    Dec 2001
    Chelmsford, Essex,
    any Vectra will do but the later ones came with painted handles on GLS upwards.
    Can't rememeber what operating rods I used in the end for the drivers lock, but the one from the Late astra backplate should be fine.
    May 2004
    eDINBURGH
    1992 1.4i 8v astra
    are any handles a straight replacement?
