Results 1 to 17 of 17
Thread: What else can u blend in bodykits with?
    Aug 2003
    Newport- South Wales
    Shexy modified Manta
    Filler cracks and it seems as those this sikaflex stuff ain't working either, seems too flexible as the stuff don't dry hard. I've tried it out to see if it can be smoothed into the bodywork but it doesn't even bond things together very tight let alone sand smooth. It's meant to stay flexible. Anyone got any suggestions?
    I wasn't going to blend the arches, skirts, bumpers and everythingelse in with sikaflex seens as it is apparently strong but the stuff I have is crap, bathroom sealer is better than this rubbish. if it was strong enough it would be perfect for smoothing everything in. But i'm thinking of trying tigerseal maybe? Tigerseal to bond it all down as tight as I can so it doesn't move atall then filler to smooth it in? Hopefully it won't crack then. Wondering wether to try some fibreglass resin in with the sikaflex or abit of filler in with it so it can be sanded smooth and not peel off.
    Bit annoyed at how bad this sikaflex is! Sikaflex 265 technique I bought. Tigerseal next I think.
    please DrIvE slowly
    Oct 2001
    Herts
    Grale, Mustang, 535i
    Re: What else can u blend in bodykits with?
    Can't you get fiberglass filler stuff? Try that.
    Mike
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    yeh, p40 and then some p38 over the top to get smooth finish
    Aug 2003
    Is that what they normally use? I already have a full tin of P40 knocking about, I'll give that ago anyway. Ain't P38 normal filler? just more expensive cause I can rememebr trying everywhere local to get hold of it.
    please DrIvE slowly
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    Thats what I use, and it hasnt cracked for about a year (as long as Ive had it on) and I blended in my skirts with it. Still, time will tell I guess
    MY ASTRA 3 FOR SALE - UNIQUE SHOW CAR, ONLY now £1295ONO - http://www.migweb.co.uk/forums/showthread.php?t=235022
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    oh, and i get the stuff from Maccess or when im real desperate, hellfrauds
    Jul 2004
    oxford
    turbo astra mk3
    what i did with mine was use pop rivits to hold it then used p38 to go over it that way it cant move and wont crack
    Aug 2003
    that aint a bad idea actually, i'm just worried about the bear metal if using rivets. The skirts will be easy because i'll have metal brackets bolting the thing solid to the car, wont move even if I step on them that way.
    please DrIvE slowly
    Jul 2004
    oxford
    turbo astra mk3
    well what i did was fill over the rivits that way u dont see them and noone will ever pull them off better than any glue
    MIGWeb User IrmscherZafira's Avatar
    Nov 2003
    Staffordshire
    Irmscher Styled Zafi
    Quote Originally Posted by pre-auto.com
    It doesn't set rock hard, it forms a paintable skin which remains flexible to prevent cracking, unfortunatly (as you have discovered) you can't sand it.
    It's a good adhesive if left long enough.
    Since turning 30 I've become a grumpy old f*rt, for this I apologise
    Aug 2003
    I went around gluing crap to things, bolts and screws and stuff to metal tool cabinets left them probably about 12 hours, came off with a little tug. What dyou reckon 48 hours try it?
    please DrIvE slowly
    Nov 2003
    Staffordshire
    12 hours sounds about right TBH.
    What about bumper repair filler, I've used it before to repair a bumper it's sandable and suppose to remain flexible.
    Aug 2003
    I tried mixing filler with it to see what happens on one area (didnt work) but I found the best way now i think. Sikaflex first then filler on top of it seems to work the filler seems to attach to it better than it attaches to metal. I may try gluing some more things together but leave it 24 hours and clean the surfaces this time see what happens. Just hope the filler doesnt sink into the sikaflex.
    please DrIvE slowly
    Nov 2003
    Staffordshire
    The kit on my old car was stuck on with a combination of a few screws and sikaflex, the sikaflex was smoothed off and the car sprayed when it had gone off.
    Aug 2003
    very nice, you can buy this primer stuff u put on first cant u specifically for sikaflex? did u do it with that or not bother?
    please DrIvE slowly
    Nov 2003
    Staffordshire
    didn't bother.
    In all fairness a garage did it for me while I watched. (think I've got some photo's somewhere, step by step.....how sad lmao )
    They attached the kit with silkaflex and a few screws or rivets, smoothed it off with thinners and left it for a few days with clamps holding everything in place.
    Feb 2002
    Co. Kerry, Ireland
    2.0 Nova, Astra Mk3
    Quote Originally Posted by shakey1975uk
    Problem is, filler will sink into rivets after a while. Best thing to do is countersink the rivets into the kit, grind the heads down slightly to bring them flush with the surface, then use fibreglass or P40/fibreglass filler over the top to cover them up. Then smooth off with P38
