Paint Job
Page 2 of 2 FirstFirst 1 2
Results 26 to 29 of 29
Thread: Paint Job
  1. #26
    Aug 2004
    Re: Paint Job
    high gloss thinners are better than the ones listed as antibloom, they dry the slowest, its the very fast thinners that bloom due to cooling the air as they evaporate, condensing the water in the air around, the water then enters the paint and makes it go cloudy/white
    if you paint in warm weather it can be worse due to moisture in the air and the temp speeding up the evaporation, the winter can be better to spray! its actualy dryer if its not raining.
    Mar 2004
    Nottingham
    Ventora & Yanks
    Re: Paint Job
    I was thinking of the very high relative humidity we've had in the last few weeks, bloom is the only significant drawback of celly paints.
    Good tip on the high gloss thinners. Never thought about it like that and it does make sense. I'll try that next time, I've a car I'll be doing a full respray on in the next couple of weeks.
  4. #28
    Dec 2003
    Leicester
    WoRkInG On It
    Re: Paint Job
    the car has a lot of rust on it, should i sand it down, apply anti-rust product and then primer b4 i spray?
    T
  5. #29
    Oct 2001
    Herts
    Grale, Mustang, 535i
    Re: Paint Job
    Yes, remove all the rust first, apply some anti-rust stuff, and then use some acid etch primer (chromated if you have breathing apparatus). Then prime/topcoat as normal.
    Mike
