Results 1 to 6 of 6
Thread: Rust repair?
    Jun 2004
    W. Yorkshire
    1994 Corsa GSi 16v
    Rust repair?
    wondering what it would cost to get some rust taken out on my doors and tailgate?
    Both doors have rust spots near the bottom about an inch diameter, and one has a 2 inch crack in the paintwork which is rusting. Rust on the tailgate is only minor.
    can this be repaired or do i need new doors?
    MIGWeb Moderator
    Midlands
    Nowt
    Re: Rust repair?
    Have a drive round some body shops and get some quotes.
    May end up getting a new door, phone a few brakers and see if they have any in the same colour as yours.
    Thats what I did with my Astra, loads cheaper.
    Paul
    Jun 2004
    Stamford, Lincs
    MK2 Astra SRi, GT4
    Re: Rust repair?
    depends how much rust it has on it. Often there is a lot more than what you can see straight away. If you can find a door from a scaprry in good condition that woul dbe ideal
    Astra SRi MK2 2.0 8V
    Mazda 323 1.6 Turbo 4X4
    Add your 1/4 mile time! http://www.aj-computing.co.uk/misc/quartermile/
    Jun 2004
    W. Yorkshire
    1994 Corsa GSi 16v
    Re: Rust repair?
    cheers ill check a few places out. dont wana get new doors if i can help it, but yep might be the only way if the rust is worse than it looks
    Jan 2003
    Blackpool
    Re: Rust repair?
    Probably cheaper getting a good new pair of doors from a scrap car, but failing that, look for a bodyshop which does S.M.A.R.T. repairs. These bodyshops specialise in small-area repairs and restoration
    "Sex without love is an empty experience, but, as empty experiences go, it's one of the best." — Woody Allen.
    Aug 2003
    Newport- South Wales
    Shexy modified Manta
    Re: Rust repair?
    if its repaireable (I imagine it is) basics of rust repair is grind it back as far as u can go every spec of rust has to be grinded back. rust treatment on that then rust primer if you like (isn't strictly needed) then blend it in with filler if need be and spray it. remember filler aint waterproof. See how much new doors would be first though.
    please DrIvE slowly
