Results 1 to 15 of 15
Thread: How much material????
    Nov 2003
    Croatia
    Corsa B, 1.5TD, 1998.
    Is needed for re-trimming the door cards? In meters, pls.... Ooops!!! Itīs for a Corsa B (ī98). Tnx!
    SMOKINī!!!!!!!
    Aug 2003
    Newport- South Wales
    Shexy modified Manta
    Re: How much material????
    measure them and then u'll know ya numpty
    please DrIvE slowly
    Nov 2003
    Croatia
    Well, seems Iīll have to. Iīm very lazy so I guessed someone would give me the exact numbers....
    Does any1 know how the door cards look in red-black combination??? I mean, I called an ad, and the man told me he has red-black combination door cards for a Corsa B. So, do you know how this combination looks if they are factory made from opel/vaux??
    Oh, the prize was 67 euro for 4 doorcards. Itīs like 50 pounds..... Is it worth???
    SMOKINī!!!!!!!
    Apr 2004
    Derbyshire
    Calibra V6 again :)
    who did you ring? i am not completly sure how to recover the door cards in my astra mk3. do i need to take the door card to pieces? i ask this because they have plastic pieces on the back holding the fabric onto the doorcard. Or do i just need to cut the material out and glue it over the existing material?
    Nov 2003
    Croatia
    Who did I ring??? LOL!!! Iīm from Croatia so I donīt think that I can help u much with that info. Iīm not sure jet. I want to see the door cards man offered to me, and if I donīt like them, I will glue the material over the existing one. U would have to take the doorcards off to make the job properly...
    SMOKINī!!!!!!!
    Jun 2002
    Ware, Herts
    Corsa 1.5 TDS 99 bhp
    no, pull the old material off first, it doesnt stick very well unless oyu pull it off, i know from experience.
    1993 corsa 5 door 1488 cc TD 99 bhp 132 ib/ft torque soon to be a lot more ;)
    Apr 2004
    Derbyshire
    Calibra V6 again :)
    how can you pull the old material off? if i take to door card off, can i just pull the material off it then?
    Nov 2003
    Reading/Brighton
    Astra Mk3 Cesaro
    Quote Originally Posted by C3RSA
    ahem...4-2...
    sorry!
    I reckon red/black combination will look well smart!
    Oh and to change the material on astra mk3 door cards, I think you have to drill out the rivet things holding the material in place and then use short screws to attach the new material in place (will see what I mean when you take door card off) although I have not done this yet
    Nov 2003
    Croatia
    Cesaro> u should see our newspaper.... Our manager got sacked immediately.... We played a good 20 min on Euro-against France, and that was all... Theyīre piece of s*it!!!
    Sorry for OT.
    So, did u see the mentioned combination made by Opel or did u see some home made???
    SMOKINī!!!!!!!
    Jul 2003
    Exeter
    Astra 1.6i GLS
    I have a home made job.. with red leather at top and black at bottom, cesaro. That is a really smart idea about using small screws to rettach it! I used a glue gun and it took for each for it to set!
    Bitches in the back, tunes pumping.. lets get moving.
    Aug 2003
    got any pics of that? Wouldn't mind having a look
    please DrIvE slowly
    Jul 2003
    Exeter
    Astra 1.6i GLS
    not at work.. but can put some up later
    Jul 2003
    Exeter
    Astra 1.6i GLS
    Sorry it took so long.. took them with my phone and forgot to upload them.. but here they are... hope you like.
    Nov 2003
    Croatia
    I like it. Did u just glue it on the old material or u pulled it off??
    SMOKINī!!!!!!!
    Jul 2003
    Exeter
    Astra 1.6i GLS
    gluded on top... Gives the glue something better to stick to.. but use loads!!!! trust me no this!
