removing body panels
how do remove the black plastic body panel that sits behind the number plate on the Astra GSi, mine has come loose from the clips and i want to take it off replace the clips and put it back on, i have tryed gluing it on but it keeps coming loose.
Ivan m
Re: removing body panels
theres about four large vertical clips along the length of the panel that are just a clip fit,
there are the two screws that hold the number plate, that go through the panel,
and also two screws on the back of the locking barrel.
you need to take the plastic trim panel out from inside the boot(about 10 torx screws holding it in) then you will be able to undo the screws on the lock!
then the black panel will come off with a tug.
