Nova Mk1 Dashboard Removal
have undone all bits, removed spedo, steering wheel, all electics, blah blah... apart from the face level vents in the centre... can someone tell me what is required to remove the vents and the control panel / clock from the front of the dashboard?
cheers, Andrew
Re: Nova Mk1 Dashboard Removal
If you push the vents up as far they'll go, you should see a couple of phillips screws that hold the panel in place - they screw up into the bar that's just beneath the hole for the radio. When the screws are out, pull the panel forward and lift it out of the slots at the base. The switches/clock all just clip into place in the panel, as you'll see when you're removed it
