Results 1 to 4 of 4
Thread: Top Coat Peeling/Cracking
    Mar 2004
    Surrey
    MK3 Astra 2.0 Sport
    In some small areas on the bodywork the lacquer/top coat is starting to peel and crack . It's not really bad at the mo but I want to put a stop to it before it gets that way....
    Has anyone else dealt with this problem sucessfully?
    Cheers for any advice.
    Ben
    MK3 Astra 2.0 Sport - Custom K&N Cone, Vectra V6 Brakes, Proxes T1-S, Strut Brace, Kenwood ICE
    MIGClub Member angryman's Avatar
    Mar 2004
    N W London
    2.0 16v Vectra SRi
    Re: Top Coat Peeling/Cracking
    Have just done the top of my SRi drivers door with the same prob(about an inch of damage) Picked off the edges of the damaged laquer,rubbed it down locally to smooth the edges. I then masked of locally around the area and sprayed with Halfords colour match to build up the level, letting it dry in between coats. Rubbed down with 1200 grit and soapy water then re laquered.
    Finish is good (not bodyshop finish, but you'll never get this) .... only if you stick your face right up to it would you know it's been done
    Need to do the spoiler at some time as this has bits going
    Mar 2004
    Surrey
    MK3 Astra 2.0 Sport
    Cheers Angry - Like the new wheels BTW
    Does this method work Okay on metalic paintwork as well?
    Mar 2004
    N W London
    2.0 16v Vectra SRi
    Would have thought so, but with a bit more care with the spraying (more frequent lighter coats), as metallic has a laquer as well
    If yours is metallic, try doing a bit (if there is one) that is more out direct sight on the car first!
    As for the wheels
