Results 1 to 16 of 16
Thread: Fitting vectra door handles to cavy
    Oct 2003
    North Scotland
    Jus got a set of colour coded handles of ebay (na na to anyone who was also bidding )
    Will they jus fit straight on????
    My mate reckons e only way at Santa gets all them presents delivered in one night is "cos hes got a 360bhp C20LET nova"
    Thought it might be true untill i remembered it SNOWS at Christmas , "MUST BE STILL IN A CAV"
    4X4 RULES!!!!!
    Dec 2001
    Chelmsford, Essex,
    1.6LPG, 1.8, 1.9CDTI
    You need vectra backing plates.
    You need to swap the lock barrel inserts from the Cav to the Vectra, in the same order.
    You may also need to adjust the operating rods a little to make the handles and lock operate smoothly.
    Nov 2003
    Huddersfield
    Mk 3 astra 1.6 16v
    I fitted some veccy ones on my mk 3 astra and they fitted straight on!
    obviously, a cav might be different!
    lee may
    Guest
    Are you delocking too?
    If not they fit straight on if you have the backing Vectra plates, if not either front or rear cav backing plates fit but cant remember what ones
    Dec 2001
    Chelmsford, Essex,
    Quote Originally Posted by orangedan
    96> Astra handles are the same as the Vectra.
    Did you keep the Lock?
    Oct 2003
    North Scotland
    Quote Originally Posted by lee may
    Na not delocking till i get remote locking (would make it well hard to get in lmao )
    Got 4x spare doors from a gsi cav so will have the parts needed
    stupid question but how will i know which one to use eg will it all line up with correct plates and not with wrong ones, is i t rod that needs plate for or lock
    Ps must send you a pic of my car with the 18" HI-OCTAIN'S H109'S i took so long to deceide on (till i seen yours that is )
    4X4 RULES!!!!!
    lee may
    Guest
    As you are keeping the lock you need to use the Vectra backing plate with the lock in it.
    Get both barrels out and swap over the brass sliders but MAKE SURE they go back into the vectra barrel as they came out of the cav barrel.
    Dec 2001
    Chelmsford, Essex,
    The Cav backing plate holes are a different pitch so you can't mix em up.
    Oct 2003
    North Scotland
    But i can use either front or back cav plate though??(inplace of vectra plates??)
    Not sure what you mean by brass sliders as never done any work on locks b4 but im sure ill wrok it out once iv got them out and looked at them (or ill be asking you plenty more questions thankx)
    4X4 RULES!!!!!
    Dec 2001
    Chelmsford, Essex,
    You need to use the Vectra back plate for the lock.
    You'll need to fit a rear passenger handle to delock, so you may as well get it complete with backing plate.
    The passenger side has no lock.
    These are the insrets in a cav barrel
    To remove the Cav barrel there's a circlip on the back.
    On the Vectra there's a twist on/off sleeve, that has a rivet through it locking it.
    You can sometimes pull the rivet with pliers, otherwise drill it out.
    The inserts are numbered, so you could write down the order, or just line the 2 barrels up and swap them 1 at a time.
    Nov 2003
    Huddersfield
    Mk 3 astra 1.6 16v
    yeah kept the lock.
    on the passenger side just put the handle over the old lock!!
    Sticks out slightly but you can really tell!
    will get round to removing the barrel soon!
    Nov 2003
    Huddersfield
    Mk 3 astra 1.6 16v
    i meant you cant really tell!! oops!
    Nov 2003
    Huddersfield
    Mk 3 astra 1.6 16v
    Sorry, not trying to take over the thread,
    can i simply remove (if it is simple) the barrel from the passenger door handle as i have remote central locking and now have no use for it?
    is it easy?
    Mar 2004
    Sheffield
    ive just bought 1998 rear veccy door handles cheap without backing plates. can my original backing plates from my mk3 astra gsi fit. it it a 2 min job to swap over?
    Mar 2004
    Sheffield
    ive just bought 1998 rear veccy door handles cheap without backing plates. can my original backing plates from my mk3 astra gsi fit. is it a 2 min job to swap over?
    Dec 2001
    Chelmsford, Essex,
    If your AStra already has the curved handles (96 on then yes).
    If not you'll have to redrill the holes.
    To remove the passenger barrel on Standard handles, just replace with a rear handle.
