Results 1 to 7 of 7
Thread: Polycarbonate sunroof replacements
    Jan 2002
    Suffolk
    Isuzu Trooper
    Where would I get polycarbonate good enough to bond into the hole where the sunroof is coming out of??
    Oct 2000
    Portishead
    300ZX TT & Passat R
    LEXAN make top quality polycarbonate. Places like Greenham and Arco stock various quantities iirc. Different shades and thicknesses.
    Dec 2000
    Gloucester
    3MW B18iS
    Yellow Pages - Plastic Stockists.
    How are you going to just bond it in?
    No, now f*** ***.
    Jan 2002
    Suffolk
    Isuzu Trooper
    Dunnot yet.
    Maybe something like mini angle iron and then silicone around it??
    Really hadn't thought too much about the semantics of it, just the end result.
    If I could get it welded up invisibly then I'd do that... bloody thing leaks like a Bangkok whore as it is
    Dec 2000
    Gloucester
    3MW B18iS
    How about the Weekenny method:
    obtain old bonnet. Cut up. Bond over sunroof hole.
    No, now f*** ***.
    Jan 2002
    Suffolk
    Isuzu Trooper
    Only issue I'd have with that is it'd have to look neat.
    This isn't a rally slag car... for using and abusing on the track.
    I also need to chat about options and cost for instruments and stuff if I remove the dash... Anyone??
    Dec 2001
    UK
    Mini 1000
    Or see if you can find a base/Merit Astra in the scrappy, and chop half the roof panel out of it.
    Voila, the perfect curvature.
    I would fix it in place with body seam sealer. This sticks like crazy, and would be totally waterproof.
