Results 1 to 10 of 10
Thread: Vectra steering wheel in MK3 Cav Ecotec
    May 2001
    leeds
    Will it fit? Just an idea as my leather has worn through and i'm exploring the optons. Any ideas on rough prices or any other suggestions?
    Cheers,
    Ben.
    Aug 2001
    Aberdeen
    2.6 Vectra GSI
    is it an airbag model you want to put on.
    XBOX 360 GAMERTAG - Derekmack
    May 2001
    leeds
    Its already airbagged, just wondered if a Vectra wheel could be used to replace my knackered cav one.
    Aug 2001
    Aberdeen
    2.6 Vectra GSI
    dont see why not mate if its an airbag modl it should
    Jul 2000
    Airbag wheel will fit non airbag cars too.. just fitted an airbag cav turbo wheel to mates H reg calibra 16v
    BRB
    Mar 2001
    Torquay
    LC 20VT
    Whitey as done this and uses the radio controls on it to.
    Dec 2002
    Corsham, Wiltshire
    1996 Astra 1.4
    so if i get one for me mk3 astra the airbag will wire up properly and work ok?!? luckily i have never needed to test the airbag works on my astra yet, so i presume it does!!!
    Aug 2001
    Aberdeen
    2.6 Vectra GSI
    yeah it does afaik it will
    Dec 2002
    Corsham, Wiltshire
    1996 Astra 1.4
    i will also be wanting to wire up the lights behind the radio controls, i dont particularly want them to work, as i find them quite annoying, but i just want fancy lights on me wheel!!!
    Jul 2002
    Reading, Berkshire
    3.2 omega mv6 manual
    as said it will fit , you need the control unit from the vectra too (the bit that sits behind the steering wheel). also that needs a little modding to fit right , but well worth it imo the cav airbag wheel is ugly
    check here on cavweb for a bit more info : HERE
