I want to replace my old 13" with 15" alloy wheels. I was wondering about the ET... Which Et is ok for a 195 tyre without modifying anything on the car? Thanks!
SMOKINī!!!!!!!
45-49
That high??? A friend told me that his sister used to have 15" with 35 and no problems with it. Another friend had 15s with 37, and said they were ok. I donīt know... If you say 45, Iīll try them! Thanks!
SMOKINī!!!!!!!
well they will fit but the car will handle really badly and you can't lower it as the arch will sit on the wheel
any offset under a et40 on a Corsa and you will experience bad tramlining - keep to 45-49 and you'll be cool...
Thanks guys! Thatīs exactly what I wanted to hear! Cheers!
SMOKINī!!!!!!!
with anything lower than et45 you will also have to glue the rear archs on not bolt them on or it will shread the tyre. DO NOT go lower than et40.
1993 corsa 5 door 1488 cc TD 99 bhp 132 ib/ft torque soon to be a lot more ;)
Thanks Kris! Thanks everybody! At least now I know enough to prevent being fooled!
SMOKINī!!!!!!!
