Quick couple problems easy fix?
Results 1 to 8 of 8
Thread: Quick couple problems easy fix?
    Jul 2010
    devon
    Cavvy Sri
    Question Quick couple problems easy fix?
    Hi all bought a corsa 1.4i 16v sport, lowered, rear disc conversion, window tints, full interior re trim, front bucket seats, sports exhaust, full combat body kit tax and test, had cambelt failure, so got it for £175!!!!lmaolmaolmaolmao
    Any ways, sourced a tigra in OLYMPUS BREAKERS, and they kindly said 50 notes if ya remove it yourself.................................................................................. ....................1 hour later........................ i got it!!
    In my hastiness of gettin it off i didnt take note of a couple hoses
    If any one could help:
    1) the small hose off the top of the expansion bottle its on the bottle end but where does it go?
    2) on the bottom of the throttle housing is 2 brass connectors to accept hoses? not sure if 1 of these is a water hose or if they both vacuum hoses?
    The car runs but a little lumpy and wheezey, also if you give it a blip on the throttle the revs take ages to die down and idles at 1500rpm? please help proper stuck doing me head in?
    Jan 2008
    southyorkshire
    ONLY VAUXHALL WEPONS
    Re: Quick couple problems easy fix?
    small hose goes to top of radator on the right hand side if its the write radator
    not to sure about the brass connectors
    car runnin lumpy cause of one of the two ethier egr valve or idle speed sensor
    Jul 2010
    devon
    Cavvy Sri
    it does run sort of better after squeezing me hand in to plug them but have no idea wat pipes go there!! frustrating
    Jul 2010
    Axminster, United Kingdo
    astra with saab
    the pipes on the top of the throttle body are water in and water out mate ... the top hose on the expantion bottle connects to 1 of them and the other 1 goes down behind the block to the main plastic F shape water pipe .... also about this idiling problem is 1 of a few things ... the engine has bin at at the breakers for a while. so whip out the ICV and give it a good clean . and also either clean or dissconect the EGR valve .. if you disconect the EML light will come on (dont panic) just get a garage with a good diagnostic setup to turn the EGR Valve program off on the ecu . it wont cause damage to the engine ... 1 last thing .. after that if its still a problam , recheck your vacume hoses as there could be a leak .... where abouts are you from in devon mate?
    Jul 2010
    devon
    Cavvy Sri
    A water pipe on the throttle body? never have thought it? Water/fuel??
    In dawlish me self m8 always cruisin bout torquay, paignton, exeter plymouth areas bud
    still got the problem...................?
    Jul 2010
    astra with saab
    if you need a hand im in the exeter area every day as i work there and have alot of knowledge of the silly x16xe hehe ...
    Jul 2010
    devon
    Cavvy Sri
    Unhappy Re: Quick couple problems easy fix?
    Is there a certain way they go on? I.e the 1 to the top of the expansion bottle on top or bottom?
    Reason i ask is got all the pipe on but when you start the car now it revs out to the limiter and have to turnoff with the key?
    Just revs on its own................ throttle sensor?
    Bad earth?
    Jul 2010
    devon
    Cavvy Sri
    sorted it now :-)
    sortin body work and puttin up for sale
