any1 willing to help me
Results 1 to 13 of 13
Thread: any1 willing to help me
    May 2010
    hello i really stuck with my redtop as first one iv ever owed is there any1 around kent who willing to come to tunbridge wells for the day and help me get it running right will give you some money for helping and tea n coffe allday long
    Jun 2000
    Leicester
    Astra SRi 1.9 CDTI XP 3DR
    Re: any1 willing to help me
    Can't help personally, but would be worth letting us know the problems. Some people may be happy to pop along and trouble shoot with you, but not rebuild a head... if you know what I mean.
    May 2010
    not asking any one to do a head gasket or anything like that just its revving to high and miss fireing and i dont know anuff about these redtops to know what it could be
    Banned
    Jul 2002
    Bath
    Cav GSi / Omega
    Is it the dispack engine or distributor?
    Are there any air leaks in the air trunking from the air filter to the SFI box (plays havoc with the Air Flow Meter if there is)
    May 2010
    its distributor one i dont think so
    Banned
    Jul 2002
    Bath
    Cav GSi / Omega
    Start the car and unplug the air flow meter and see if that changes anything.
    MSG
    MSG is offline
    MIGClub Member MSG's Avatar
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    and check wiring and connections to engine coolant sensor (CTS) as this can make the engine run like you described overrevving and overfuelling and have all your plug leads checked for any sparks jumping etc including dist cap as the HT could be arcing along and causing misfires, rich fuelling can faoul plugs and cause misfire as well which can be caused bby the CTS sensor or bad connections.
    May 2010
    When i unplug the air mass sensor the revs drop but you go to put the throttle on and it dies
    MSG
    MSG is offline
    Apr 2005
    Isle of Dogs
    Calibra Eco 16V 2L
    yes seems Ok as it would behave like that. but get CTS sensor checked, usually its wiring or poor connections that can cause engine revving high, if you have got a multimeter you can also check the sensor which should give you a cold engine reading of approx 2000 ohms or more and on hot engine the ohms reading should drop down to around 200 ohms, i.e. 10 fold change. But my guess is it is wiring or poor joints the issue, or loose connections.
    May 2010
    what lose conections to the cts seinor or just lose conections in genral thanks ollie
    MIGWeb Moderator
    Midlands
    Nowt
    ECU light on?
    Also what car is it in?
    May 2010
    yer the ecu light is on and its a corsa b 1999
    May 2010
    Any1 please or any1 fancy a day to tunbridge wells troubleshouting with me
