LinkBack (7) Thread Tools
Old 29-07-2003, 10:22   5 links from elsewhere to this Post. Click to view. #1
MIGWeb Moderator
jamied's Avatar
Drives: GTE 3lt V6 TwinTurbo
GTE V6 T3 Nitros Plan
I have started to get into action on this because i want it 80% done by september. so far the car is sripped of everything and is on 4 axle stands plans for it are:
Body:
outside has been rubbed down to bare metal for the paint job (high shine black) and inside also...the flat square arches have been cut out and front arches have been welded in ther place, bonnet will have a scoop fitted, doors are de-locked and will have flush mk3 handels put in, tail shall be smoothed over and the plastic roof strips are removed and filled, fuel filler hole and cap are to be moved, fuel tank has been removed, cleaned and resprayed, underside of car has been cleaned to bare metal and sprayed ready for waxoil, bumper ordered from autofashion has been delived (looks an ugly thing but i have my own plans for it to make it look good), rear bumper is still being designed.
Engine:
Have a calibra V6 which is being striped and following work done,
steel rods
APR bolts
lightened fly wheel
2 mm steel head gaskets
Garrett T3 turbo placed above the gear box
Designing exh manifold
nitros system with slow release to aid turbo spool-up then shut off at set pressure.
3 lt cams
mappable ecu
Other bits:
the dash is from a mk3 astra..got it from the scrap yard for a tenner and did a paint job on it...put it in the car for a test but its in a storeage box at the moment.
the fuel system that sits under the car at the back is ging to ba transfered in to the boot along with the battery.
rear seats are scraped and a fake floor will be put in to hold the nos tank and amp.
bucket seats and harness.
v6 hub and brake set-up
display lights (under neons, side light switches, ect)
set of smiths dials in stead of digidash.
phew.
im hopeing to get a web site set up this weekend to put the pics on and progress the work.
as a taster here is a pic of the dash when i tested it out first time.
3ltr V6 Twin Turbo RWD GTE with a touch of NoS http://www.migweb.co.uk/forums/showt...threadid=90683
J.A.D.E Performance ...... Open For Business...Mobile Mech..Repairs..Modding..jadeperformance@hotmail.co.uk
jamied is online now   Reply With Quote
Old 29-07-2003, 10:26   #2
Drives: BMW
if you actually complete this beast it will be awesome
FWD tho? any lack of traction gen..
The Vauxhall Bug; Once Bitten Forever Smitten
Jhonno is offline   Reply With Quote
Old 29-07-2003, 10:31   #3
MIGWeb Moderator
jamied's Avatar
FWD should be ok bit of spin here and there but thats part of the fun
i think i might by a few shares in some local tire companies..
Old 29-07-2003, 11:18   #4
Drives: Astra 1.9CDTi SRi
I have seen you posting about this before, sounds mental. What boost are you going to run 0.6bar or something?
Davo is offline   Reply With Quote
Old 29-07-2003, 11:24   #5
MIGWeb Moderator
jamied's Avatar
yep...around that pressure at the start to see how it goes.
i have a dump valve also ready to fit on it and im taking the oil cooler out from the block and fitting a new one front cross member to aid a bit more cooling. thinking about getting on of the aqumist set-ups for the intrcooler.
Old 29-07-2003, 11:32   #6
Drives: Vectra 2.0 SRI
HOLY ****!!!!!
Sorry, thats all I have to say.
TURK
Anybody got a plaster the size of a tennis ball for my gearbox????
turk is offline   Reply With Quote
Old 29-07-2003, 11:42   #7
jav786's Avatar
Drives: Vec GSI/Evo IV/Cav T
Can't wait to see it when its all done. Good Luck
If you always tell the truth, people will stop believing you!
Migweb Approved Seller!
www.Vox-All.com - Vauxhall Specialist
jav786 is offline   Reply With Quote
Old 29-07-2003, 12:21   #8
Drives: Mk1 Astra/Vectra
That sounds mental. Cant wait to see it finished
mattc is offline   Reply With Quote
Old 29-07-2003, 13:21   #9
MIGWeb Moderator
jamied's Avatar
im trying to work out a guess to how much the BHP and torque would be. Be goo to see what the 1/4 mile is also when im done...santa pod is only a couple of miles up the road from me...
Old 29-07-2003, 15:19   #10
MIGWeb Moderator
jamied's Avatar
Im taking the traction control off the v6...anybody know someone who will do the plate that fills in the gap in.?
Old 29-07-2003, 16:26   #11
Drives: 3.0 V6, 2.5 V6, 1.8
OT:
But How much work was fitting that MK3 Dashboard?
and does the centre console not fit too?
[url=http://77.96.230.10/sytemsandsoftwaredevelopment/systems.htm] How Tos
The two most life changing experiences you'll ever have. Finding Jesus, and having a baby.
Mark T is offline   Reply With Quote
Old 29-07-2003, 16:47   #12
Drives: BMW Beauty
What gearbox you having? F28? with LSD??
Hope you do it. Mental!
xx 5id xx is offline   Reply With Quote
Old 29-07-2003, 18:01   #13
DaveB's Avatar
Drives: Corsa XE with TBs
best of luck with everything, and it does sound ace.
But if your taste in interior design colour has anything to do with the outside of the car, I hold little hopes.
DaveB is offline   Reply With Quote
Old 29-07-2003, 19:32   #14
MIGWeb Moderator
jamied's Avatar
the car colour is going to be black and blue...it will look ok (i hope)
i have two gearboxes at the moment...f20 and f25....looking to see which will be ok to use.
the dash was very easy to fit mostly everything fits perfect just a few adjustment here and there but it looks go when in.
Old 29-07-2003, 19:53   #15
What Sort of "Adjustments"?
Did you change the MK2 Fuse box for a MK3 one?
Old 29-07-2003, 19:58   #16
MIGWeb Moderator
jamied's Avatar
at the top of the stearing collum you have a arch of metal that held the old dash...you can cut this away or do what i did and shorten it to hold the new dash...the fuse box and looms are being re work to get rid of the stuff i don't need but i will be using the mk3 fuse box...the central consol and the part that goes around the gear and hand brake fit ok...bit of paccking needed around the center bit but it fits ok....its very easy if you give it a goe...but use a mk3 astra dash...and not what i did first and use a mk 3 cav dash..its 1 inch to big each side...
Old 29-07-2003, 21:21   #17
Drives: GTE 16v Turbo
Neither, they are both very inadequate for the kind of torque you will have from this setup.
Contemplating lots of things
Astra GTE Turbo - Link Now Working
Cemesis is offline   Reply With Quote
Old 29-07-2003, 23:23   #18
Drives: Astra TD/Astra Sport
wana fit a mk3 astra dash into my mk2 astra dude?
btw those are some wicked plans, im sure ur car will be a one off, make sure u smooth everythin and make it stand out
Drives a minted diesel with more
stopping then engine power
Davcohen is offline   Reply With Quote
Old 30-07-2003, 08:12   #19
MIGWeb Moderator
jamied's Avatar
the car is going to be as smooth as a babys bottom..
i was trying to look for a 'better' gearbox...some told me the f28 would be a good choice and i did hear a chat about a 500bhp box avilable for vauxhalls but cannot find much on the web. if any one can guide me to a better one it would be a help.
Old 05-08-2003, 10:17   #20
MIGWeb Moderator
jamied's Avatar
Morning Gang
Please find below some pictures i took on the weekend of the progress the car is now making...should have all the welding done by this weekend...ready for paint job end of month. The car has been nearly all stripped of paint and the arch project is nearly finished.
Old 05-08-2003, 10:27   #21
cool
I want round arches now
Old 05-08-2003, 10:30   #22
MIGWeb Moderator
jamied's Avatar
the arches were Ј20 from scrap yard....
welding....freeeee
filler and sanding disks...Ј1,000,000,000
Old 05-08-2003, 11:21   #23
Gaz
Did you use a sanding disc on the end of a grinder to get the paint off? I plan on doing the same with mine when it comes to the respray.
Gaz is offline   Reply With Quote
Old 05-08-2003, 11:22   #24
Drives: 205s16
What arches are they??
James_R is offline   Reply With Quote
Old 05-08-2003, 11:29   #25
MIGWeb Moderator
jamied's Avatar
The sandind disk's are brill...i got them from a shop called Wilkinson for a fiver..one disk will do half a car and will not touch the metal...i think they sell them in screwfix also.
(115mm. Removes paint, varnish, rust and scale without damage to metal, wood, fibreglass, granite, brick and stone. Non clog. 8mm arbor.)
The arches are just astra mk2 or 3 fronts cut and put on to the rear.
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/90683-astra-gte-3-ltr-v6-twin-turbo-rwd-nos-plan.html
Posted By For Type Date
..на ретро не совсем похоже.... - Ukrainian Opel Club This thread Refback 22-05-2008 12:15
..на ретро не совсем похоже.... - Ukrainian Opel Club This thread Refback 22-05-2008 11:30
..на ретро не совсем похоже.... - Ukrainian Opel Club This thread Refback 22-05-2008 11:09
rwd astra mk3 - Vauxhall Astra Mk3 Owners' Club This thread Refback 25-03-2008 17:32
Surftipps und Empfehlungen This thread Refback 02-10-2007 18:42
Kev Read - PROJECT YB - Page 5 - Astra MK2 Owners Club This thread Refback 16-01-2007 10:12
Der Opel-Sechser Talk :: Thema anzeigen - Kadett Bi-Turbo This thread Refback 14-01-2007 16:17
Members: 42,547
Threads: 308,196
Top Poster: LEE69 (42,904)
Welcome to our newest member, angelillo
