LinkBack (7) Thread Tools
Old 06-02-2005, 22:29   #176
MIGWeb Moderator
jamied's Avatar
Drives: GTE 3lt V6 TwinTurbo
Had a late start on the car this saturday due to a mates car needed looking at first so i have only got a few bits soted this weekend, side skirts came and also i fitted the skirt to the front bumper and started to mesure up for the pipe work for the manifolds and the intercooler, also finished agout 80% of the electrics (cheers for the loom badastra) below are a cople of pick of the bumper and skirts...more to follow.
3ltr V6 Twin Turbo RWD GTE with a touch of NoS http://www.migweb.co.uk/forums/showt...threadid=90683
J.A.D.E Performance ...... Open For Business...Mobile Mech..Repairs..Modding..jadeperformance@hotmail.co.uk
jamied is online now   Reply With Quote
Old 07-04-2005, 11:32   #177
MIGWeb Moderator
jamied's Avatar
afternoon gang, since the weather this weekend looks as if it is going to be ok im going to finish off the boot by welding in a new floor and finish the electrics off (95% done), my new Smiths dials came today and look real smart so i shall be fitting them also (shall put a pic of them up later), the hubs are all now 5 stud hubs with v6 calipers and i have also have found the fuel tank which im going to stick in the boot, shall be getting it the end of the month... http://www.proalloy.co.uk/cgi-bin/sh...93&id=proalloy ... after that its just fitting the engine back together and firing her up...
Old 07-04-2005, 11:36   #178
Drives: ZX Volcane TD
Great stuff. How did you get on with the manifolds?
Never stick your finger where you wouldn't stick your dick and you won't go far wrong.
Paul Baldwin is offline   Reply With Quote
Old 07-04-2005, 11:41   #179
MIGWeb Moderator
jamied's Avatar
hummmm...not so much manifold but something that looks like a ride at Alton Towers... ..from rear manifold down..under enging to front of car where it meets the manifold from the front of the car were both go up to the turbo positioned to the right of the front head in front of the gearbox...i shall get some pics of it this weekend when the engine is on the stand and i can fiish it off.
Old 07-04-2005, 11:53   #180
Drives: Fear into children
Awesome project been great seeing this thread bumped back to the top every now and then ..
Ginge
A man goes into a library and asks for a book on suicide.
The librarian says, "**** off, you won't bring it back."
Ginge is offline   Reply With Quote
Old 07-04-2005, 20:46   #181
MIGWeb Moderator
jamied's Avatar
As promised here is a quick pic of the Smiths dials i got this morning and shall be going in the car this weekend with the rest of the electrics. There is a Fuel guage, water temp, oil temp and Turbo pressure. The oil pressure and speedo shall be coming end of month when i order them. Sorry the pics are a bit bad i think i have bust my camera.
Old 07-04-2005, 23:06   #182
CraigG's Avatar
Drives: E30 318is
hows the engine coming along?
CraigG is offline   Reply With Quote
Old 07-04-2005, 23:12   #183
MIGWeb Moderator
jamied's Avatar
getting there...checking ways of cooling pistons 5 & 6 due to i have been told that they might overheat, still looking for the pistons but have found that Courtneys sell them off the shelf for Ј750, Accurite are around Ј900 but waiting period, but im getting a few feed backs from the usa from companys that can do them for around $500. Bar just a few set-backs its getting there.
just cheacked a thread on here that vauxhall did a prototype engine and might have parts but i had a look on the EPC and found nothing...
Old 08-04-2005, 12:29   #184
Drives: single turbo rx7
coming along very nicely mate. got any pics of the manifolds, engine etc??
on EPC search for C25LET, this is what it was going to be called and started production of the parts i think but it got discontinued.
i miss my vauxhalls breaking down
astragsi is offline   Reply With Quote
Old 08-04-2005, 12:47   #185
MIGWeb Moderator
jamied's Avatar
i shall have a look when i get home..just want to see if vauxhall do the turbo pistons for them still, and if there a bit cheaper than Courtneys. i shall get a few pics this weekend.
Old 08-04-2005, 12:56   #186
if they still did them i dont think they will be very cheap, also i dont think they will be as strong as the courtney ones considering your going to be running a T3 and nitrous
look forward to the pics
Old 11-04-2005, 14:58   #187
Drives: 3.0V6 Corsa With NOS
standard LET pistons Fit the 3lts
BeArDy is offline   Reply With Quote
Old 15-05-2005, 21:30   #188
MIGWeb Moderator
jamied's Avatar
Anyone got a 3ltr block for sale???? lol...and a few LET pistons...
Old 15-05-2005, 21:46   #189
Drives: Coupe Turbo
Good to see this project is still alive and kicking Jamied!
Why whats happened!
Caul Pope is offline   Reply With Quote
Old 15-05-2005, 22:08   #190
MIGWeb Moderator
jamied's Avatar
finding it a bit hard to get pistons less than Ј1200. courtneys seem to be the cheapest around but i was thinking..3ltr..LET pistons..bit more power..hummmm...its probaly because i've given myself about 30 electric shocks this weekend finishing the wiring in the car that im looking for easy fittings for now so i can get out to the shows and track days..
Old 26-05-2005, 20:45   #191
MIGWeb Moderator
jamied's Avatar
Evening gang, the v6 turbo project has took a bit of a turn with the 2.5 ltr engine....its now a 3 ltr.... ...picking up the heads and block with crank tomorrow...and the 2 ltr turbo pistons should fit in like a dream which means with any luck i should fire her up in the next 4-8 weeks..
Old 27-05-2005, 18:37   #192
sweet mate, sounds good to me, get some more pics up when its coming along nicely.
Old 28-05-2005, 18:33   #193
MIGWeb Moderator
jamied's Avatar
picked up the v6 3ltr yesterday evening...i got...two 3ltr heads (no cams), 3ltr block, crank, water pump, oil pan and bits, all for Ј150. stripped it down today to cheak it all over, piston rings were focked and some damage to pistons but everything else was perfect even the cylinder bores. Now the plan will be get some turbo piston from a couple of 2lrt LET's swap the rods from the 2.5ltr over to the 3ltr and get a couple of strong gaskets made for the top end. Also the 3ltr was from a auto, the flywheel was like a piece of paper...why are they so light? Pics will be on here monday night as i forgot the lead for the digi camera....
Old 28-05-2005, 18:43   #194
awaits pics.... 6 LET pistons are going to cost quite a bit tho.
Old 28-05-2005, 22:23   #195
Ј90 each QED motorsport (forged)
big dal is offline   Reply With Quote
Old 28-05-2005, 23:02   #196
Drives: 1985 Mazda Rx7
a handful were bunged into calibras apparently, but weren't too reliable..
Powered by aghhhhhhhhhhhh technology!!!
SmokeyGsi is offline   Reply With Quote
Old 30-05-2005, 20:21   #197
MIGWeb Moderator
jamied's Avatar
evening gang...as promised here are a few pics of the work over the weekend...most was done on the inside getting it ready and then stripping the engine down and cleaning it...
the 3ltr block
the heads
the oil pan and bits
car inside saturday morning.
car inside saturday morning after 2nd coffee
car inside sunday afternoon
need a few more dials.... .......
more to follow..
Old 30-05-2005, 21:31   #198
MIGWeb Moderator
jamied's Avatar
nearly forgot to ask a few techy questions,
when running the turbo what Air Flow Meter should i use?
Can i use the LET turbo flywheel and clutch with the V6 and F28?
And im i two minds on going for a locked transferbox, what power can you shove in to it?
Old 30-05-2005, 23:21   #199
Drives: 3.0 V6, 2.5 V6, 1.8
The Auto flywheel is just a starter ring, that's why it's small.
The Turbo, or XE clutch and flywheel will fit, but you need the relevant clutch disc for your chosen gearbox.
the V6 Airflow meters are good for at least 250 BHP, with the standard V6 ECU, although you'll need an ECU capable of controlling Boost.
[url=http://77.96.230.10/sytemsandsoftwaredevelopment/systems.htm] How Tos
The two most life changing experiences you'll ever have. Finding Jesus, and having a baby.
Mark T is offline   Reply With Quote
Old 31-05-2005, 17:29   #200
MIGWeb Moderator
jamied's Avatar
i had a look at some of the prices for pistons and found that the Forged pistons for turboed C20XE/C20Let engine in any compressio ratio you want: Ј270 that Matheus428 is selling on his thread http://www.migweb.co.uk/forums/showthread.php?t=192996 should fit my 3 ltr ok and the price and quality looks good also...he couldn't do the ones for the 2.5 ltr as the cost for a new mould would have pushed them up.
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/90683-astra-gte-3-ltr-v6-twin-turbo-rwd-nos-plan.html
Posted By For Type Date
..на ретро не совсем похоже.... - Ukrainian Opel Club This thread Refback 22-05-2008 12:15
..на ретро не совсем похоже.... - Ukrainian Opel Club This thread Refback 22-05-2008 11:30
..на ретро не совсем похоже.... - Ukrainian Opel Club This thread Refback 22-05-2008 11:09
rwd astra mk3 - Vauxhall Astra Mk3 Owners' Club This thread Refback 25-03-2008 17:32
Surftipps und Empfehlungen This thread Refback 02-10-2007 18:42
Kev Read - PROJECT YB - Page 5 - Astra MK2 Owners Club This thread Refback 16-01-2007 10:12
Der Opel-Sechser Talk :: Thema anzeigen - Kadett Bi-Turbo This thread Refback 14-01-2007 16:17
Members: 43,212
Threads: 310,613
Top Poster: LEE69 (43,150)
