20-06-2004, 19:46
#101 | | MIGWeb Moderator
Join Date: May 2003 Location: northampton Drives: GTE 3lt V6 TwinTurbo
| Re: GTE V6 T3 Nitros Plan Busy weekend again..im now about 90% near to finishing the rear suspention for the 4x4..next week it should be all on and the rollcage finished aswell ready for painting.. below are some pics of the modifications i had to do to the suspention arm to make it fit the astra mk3...the rest shall be on the website im doing with all of the mods i have been doing to my gte.
the rear tube-beam is cut and a solid 38mm steel beam pushed in to strenten and extend the unit.
the sub frame is drilled and steel plates and bolts are usd to hold the arms in place.
the bolts go all the way in to the boot area..now the beam is in the right place the steel rod section and beam or welded so the whole unit is solid. |
21-06-2004, 12:27
#102 | | MIGWeb User
Join Date: Sep 2002 Location: Bedfordshire Drives: VW Golf GTi
| Re: GTE V6 T3 Nitros Plan Getting there!
Ill have to whip over and have a look at this soon Jamie. |
21-06-2004, 16:31
#103 | | MIGWeb Moderator
| Re: GTE V6 T3 Nitros Plan Any time teddy...give me a call on my mobile when you want to come over...im up at the car every weekend. |
27-06-2004, 21:15
#104 | | MIGWeb Moderator
| Re: GTE V6 T3 Nitros Plan |
27-06-2004, 21:21
#105 | | Guest | Re: GTE V6 T3 Nitros Plan 11month project so far boss
still going well by the looks of it | |
27-06-2004, 21:44
#106 | | MIGWeb User
Join Date: Jul 2002 Location: Stowmarket, Suffolk Drives: Astra 1.7D Estate
| Re: GTE V6 T3 Nitros Plan Jebus |
27-06-2004, 22:36
#107 | | MIGWeb User
Join Date: Nov 2002 Location: Plymouth Drives: Another S14
| Re: GTE V6 T3 Nitros Plan Immense project |
28-06-2004, 10:56
#108 | | MIGWeb User
Join Date: Sep 2002 Location: Stourport, Worcester Drives: ZX Volcane TD
| Re: GTE V6 T3 Nitros Plan Keep it up jamied, really want to see this motor at one of the shows
__________________ Never stick your finger where you wouldn't stick your dick and you won't go far wrong. |
28-06-2004, 11:16
#109 | | MIGClub Member
Join Date: May 2001 Location: South Wales Drives: Cav Tbo Evo5 on 18's
| Re: GTE V6 T3 Nitros Plan man im thirsty and need a fag after reading them pages  keep it going
__________________ I love MIG...MIG loves meeee...like one big gooOy F A M I L E E E |
21-07-2004, 19:53
#110 | | MIGWeb User
Join Date: Dec 2002 Location: Rainham Kent Drives: mk216v,rover,escort
| Re: GTE V6 T3 Nitros Plan Any more progress mate?? |
21-07-2004, 19:57
#111 | | MIGWeb User
Join Date: Mar 2004 Location: Northamptonshire Drives: MK3 Astra Sport 2.0L
| Re: GTE V6 T3 Nitros Plan Can we have the pics back up? Take it they were uploader pics.
Want to see this car, eyes will be peeled! |
21-07-2004, 20:56
#112 | | MIGWeb Moderator
| Re: GTE V6 T3 Nitros Plan new pics shall be up this weekend...picked up the F28 last weekend and i have a FMIC on the way also...shall put most of the engine together to show where the turbo sits and posision in the engine bay next week as im on holiday (doing the car)..finishing off fillering and then i can do the paint job and rewire the whole beast. |
22-07-2004, 00:08
#113 | | MIGWeb User
Join Date: May 2002 Location: Southend Drives: VXR Vectra
| Re: GTE V6 T3 Nitros Plan really looking forward to this mate, keep up the hard work
__________________ VXR Vectra |
12-08-2004, 18:33
#114 | | MIGWeb User
| Re: GTE V6 T3 Nitros Plan Any more progress mate? I am interested in the rear damper arrangement as mine is about 4" out and am considering moving the turrets closer to the irs.
__________________ 'spice world' |
12-08-2004, 18:40
#115 | | MIGWeb User
Join Date: Jul 2001 Location: Oldham, Lancs Drives: 3.0V6 Corsa With NOS
| Re: GTE V6 T3 Nitros Plan want to see the turbo setup on the V6 |
12-08-2004, 22:43
#116 | | MIGWeb Moderator
| Re: GTE V6 T3 Nitros Plan Have some pics now, what uploader are we all using now???  |
12-08-2004, 22:46
#117 | | MIGWeb User
Join Date: Jan 2002 Location: ayrshire scotland Drives: like a saint-9points
| Re: GTE V6 T3 Nitros Plan i use photobucket. http://www.photobucket.com/
rodgerq
__________________ thick red - battery, thin black - igntion switched feed, thick red/blue - fuel pump, brown/blue - ecu light. thin green - rev counter. scrap metal/car lying about? free local uplifts. WANTED, old alloys, exhausts, cats, g/boxes etc. pm me |
12-08-2004, 23:08
#118 | | MIGWeb Moderator
| Re: GTE V6 T3 Nitros Plan OK here we go....turbo setup..starting on the pipe work this weekend, pics below:
The turbo bracket is fixed to the old oil-cooler plate, oil cooler is on the front now. the bracket still needs a bit of work to angle the turbo a bit more.
with the turbo temp fitted.
My smallish Nos tanks and where they will sit.
And the dash fitting and rewire started (chucked out about 15kg of rubbish wire)
more pics to follow this week end.  |
12-08-2004, 23:11
#119 | | MIGWeb User
| Re: GTE V6 T3 Nitros Plan quality pics as usual mate
that dash looks sweet!! mind you that engine isnt exaclty shabby either, lol
rodgerq |
12-08-2004, 23:18
#120 | | MIGWeb Moderator
| Re: GTE V6 T3 Nitros Plan cheers rodgerq mate, should have some pics of the engine and pipework set up in the bay, when i test the fitting in the next few weeks. |
13-08-2004, 12:18
#121 | | MIGWeb Moderator
| Re: GTE V6 T3 Nitros Plan Sorry AJRAT, i forgot to give you an answer..have you by chance got a pic of the problem and i can see what i did..im getting a set of second hand dampers this weekend to mesure up on mine. |
13-08-2004, 12:34
#122 | | MIGClub Member
Join Date: Apr 2002 Location: High Wycombe Looks@: Drives: The White Wonder
| Re: GTE V6 T3 Nitros Plan nice!
It would be class to get the old pics back up as well mind
__________________ LURF - The proper pronunciation for "love". Especially emphasized during karaoke sessions.
"Oh, my lurf, my laling, I hunger for your tush, a long and lonely time..." Total Carlton (Carlton Forum) |
13-08-2004, 12:47
#123 | | MIGWeb Moderator
| Re: GTE V6 T3 Nitros Plan shall try to put a few up...have them all on a disk and im setting up a big(ish) web site to show the work and any how-to-do files. |
13-08-2004, 17:00
#124 | | MIGWeb User
| Re: GTE V6 T3 Nitros Plan Quote: |
Originally Posted by jamied Sorry AJRAT, i forgot to give you an answer..have you by chance got a pic of the problem and i can see what i did..im getting a set of second hand dampers this weekend to mesure up on mine. | No worries  . I havnt got a pic as yet, but basically the gte dampers are 6" short of the irs mounting points! I am probably going to move the turret lower down (just drill the spot welds and it comes away). Also what are your plans for the fuel tank? I have offered the calibra plastic one up and it hangs quite low. Probably a case of cutting the chassis rails a bit to allow it another couple of inches.
Cheers, Adam |
13-08-2004, 17:18
#125 | | MIGWeb Moderator
| Re: GTE V6 T3 Nitros Plan sticking the tank in the boot...lol...easy and simple..looking in to some double layer plastic tanks. |
Members: 43,212
Threads: 310,611
now!
of being a MIGClub Member.
