LinkBack (7) Thread Tools
Old 01-09-2005, 14:18   #251
Regional Co-ordinator
spanishfly's Avatar
Drives: ACT Nova TBs & less
@ pic
spanishfly is online now   Reply With Quote
Old 01-09-2005, 14:28   #252
Drives: Astra coupe turbo
this project looks awesome, i hope you get it finished and running sweet.
mattcoupturbo is offline   Reply With Quote
Old 01-09-2005, 14:47   #253
MIGWeb Moderator
jamied's Avatar
Drives: GTE 3lt V6 TwinTurbo
Ј6000...
so far this 'little' project has set me back about Ј3000 and that is from buying the car upto getting the sandpaper for painting. Next big cost is going to be the ECU (quoted Ј750) its took me a few weeks looking for good bargin parts but it has paid off in the end, also doing a lot of work myself has made it much cheaper.
3ltr V6 Twin Turbo RWD GTE with a touch of NoS http://www.migweb.co.uk/forums/showt...threadid=90683
J.A.D.E Performance ...... Open For Business...Mobile Mech..Repairs..Modding..jadeperformance@hotmail.co.uk
jamied is offline   Reply With Quote
Old 02-10-2005, 09:00   #254
Drives: E46 BMW M3 Coupe SMG
updates!?
Ben_Lee is offline   Reply With Quote
Old 02-10-2005, 21:46   #255
Drives: V6 2.5 SRI Vectra
The picture of the 2 bottles in the back, they look like FM200 fire fighting bottles?
Jettas is offline   Reply With Quote
Old 03-10-2005, 07:20   #256
MIGWeb Moderator
jamied's Avatar
ahhhh...thats because there are... ...there the same size as the tanks im using but it easy to use them to measure up with. I have nearly finished the paint work in and outside of the car and shall get some pics up this week for you.
Old 03-10-2005, 11:33   #257
lol, where did you get hold of 2 what look like 25ltr chubb bottles
or an old style 28 litre?
i acutally work for kidde fire protection which make and sell them bottles!!
Old 03-10-2005, 11:46   #258
MIGWeb Moderator
jamied's Avatar
got them from 'smiths fire service' down the road from me...lol...they can't be used for NoS because i think the pressure used is to high for them...but they are perfect for me to use to set up positioning and were there plumbing will go.
Old 03-10-2005, 15:12   #259
what pressure does nos run at????
they're tested to about 48 bar i think.
Old 03-10-2005, 18:02   #260
950psi approx 65.5 bar
big dal is offline   Reply With Quote
Old 03-10-2005, 19:23   #261
**** me!! thats some pressure!
Old 14-10-2005, 21:28   #262
pics, need more pics!
Old 17-10-2005, 19:36   #263
MIGWeb Moderator
jamied's Avatar
evening gang
im sorting out the last bits of the underside of the car and paint work so the shell is about 90% finished and the engine is about 60% done now (pics to be done this weekend with new camera) im at the moment sorting out what i need for the suspention and what size wheels i can get away with, with a quick look i should be able to get some decent size wheels under the rear.
now comes the question part, if im going to use adjustable spring and shock set (e.g. konis) can i get rid the the nobbly bits that hold the original springs (pic below) thus helping me lower the car a bit more.?
Old 17-10-2005, 19:46   #264
Drives: like a saint-9points
if you intend to put springs back in there then youll need to keep the cups. if you are gony use coilovers that just bolt to the shcoker location then you can ditch the cups.
rodgerq
thick red - battery, thin black - igntion switched feed, thick red/blue - fuel pump, brown/blue - ecu light. thin green - rev counter. scrap metal/car lying about? free local uplifts. WANTED, old alloys, exhausts, cats, g/boxes etc. pm me
rodgerq is offline   Reply With Quote
Old 11-12-2005, 20:34   #265
MIGWeb Moderator
jamied's Avatar
Rigggggghhht, a bit of an update on the old brum-brum.
Bodywork on the car is about 80% done and at the moment im fitting the rear GSi bumper i have got to the car, and then it should be ready for the final spray job (should be over the xmas week i have off).
In the mean time i have been working on the engine and other bits and bobs..the boot and were the rear seat were has now been covered with a large metal checker sheet which is were the fuel tank and NoS tanks will sit..(pics to follow)...but today i was fitting the turbo pistons to the conrods. I had a slight problem were the top of the conrod has quite large 'shoulders' and when fitted in to the piston it fouled the base and would only let it move side-to-side about 1/4 inch, so i had to grind down the shoulders by about a millimeter...(easy)
The pins fitted perfect and in about 3 hours i had done all 6 pistons and rods.
now all i have to do is order the new shells, ARP bolts and turbo piston rings and job done...
Old 20-12-2005, 18:23   #266
Drives: none at the moument
none of the 1st pics work. all i get is a white box with a red cross
scott61985 is offline   Reply With Quote
Old 20-12-2005, 18:30   #267
MIGWeb Moderator
jamied's Avatar
hummmmm....the first lot of pics at the begining are not there (shall try to replace them) but the new should be...not gone top secret yet shall also get some more over the xmas holiday.
Old 18-01-2006, 23:35   #268
Drives: vectra 2000 16v 91`
any updates ?
GeorgeGt is offline   Reply With Quote
Old 19-01-2006, 08:08   #269
Drives: 400 BHP Skyline GTR
have you already got the turbos? I have some low lag Skyline turbos good for 1bar and 450 bhp.
My Skyline for sale, PM me or see for sale section.
observer is offline   Reply With Quote
Old 19-01-2006, 10:00   #270
Johnny A's Avatar
Drives: Saloon of Doom MKII
Can PM me regarding these, tried to send u a PM just now but your at your storage limit.
John.
Wanted - 3 door Nova, any colour/engine considered but must not be rotton
Vauxhall Carlton 2.0 16v Supercharged - Nutcase edition
Vauxhall Calibra 3.0 MV6 4x4 - How Vauxhall should have built it edition
Johnny A is offline   Reply With Quote
Old 19-01-2006, 13:16   #271
MIGWeb Moderator
jamied's Avatar
Yo! shall get some pic's hopefully this weekend, as for the turbo i have a Garrett T3 at the moment which sould give it a bit of a boost. Had a problem the weekend gone working on the car as we had two geese hanging upside down in the garage waitting to be plucked...
Old 19-01-2006, 15:13   #272
John.
send me an email at fondmetal@hotmail.com
cheers
Old 28-01-2006, 22:47   #273
MIGWeb Moderator
jamied's Avatar
Been a bit busy today fitting a new kitchen at my mates house, but i did receive my set of vectra rear lights from ebay which i shall be putting on the astra over the next few weekends... this should let me finish the rear-section mouldings for the wheel arches and bumper. i shall get some pics up asap.
Old 14-02-2006, 23:46   #274
MIGWeb Moderator
jamied's Avatar
Right, been a busy week, had a few words with people on here and a couple of engineers and i feel that a soon as i run the v6 with the 4 x 4 set up it will shread the box and trasfer box...so...im picking up a 3ltr v6 omega manual box next week to turn the astra in to a RWD and not a 4x4 drive, which means that with the engine turned around in the engine bay i can't turbo it by using both banks feeding into one turbo..shame...but it means that i can now TWIN turbo it... which will be a whole lot easyer for me, now i have the T3 garrett and are at the moment looking for another on (from a metro turbo) or should i run a smaller turbo on one side feeding into the T3 to aid spooling?
Also i have found a company on my doorstep that sell poly foam for bodywork creating, so wit the rear wheel drive and larger back wheels i could finish off with the mattig look.....
Old 14-02-2006, 23:54   #275
Colonel K's Avatar
Drives: The White Wonder
cool cool.
As for the turbo.... if its off a Metro... which was 1.3 and your putting it on a 3.0.... then it would probably work better with 2 as its then two 1.5 engines in effect. if you follow my logic.... probably wrong but hey!
You could always follow the original plan..... cut a hole in the bulkhead and have the turbo where the dash should be! wouldnt need a fag lighter then eh?
Total Carlton (Carlton Forum)
Colonel K is offline   Reply With Quote
LinkBack to this Thread: http://www.migweb.co.uk/forums/projects-restorations/90683-astra-gte-3-ltr-v6-twin-turbo-rwd-nos-plan.html
Posted By For Type Date
..на ретро не совсем похоже.... - Ukrainian Opel Club This thread Refback 22-05-2008 12:15
..на ретро не совсем похоже.... - Ukrainian Opel Club This thread Refback 22-05-2008 11:30
..на ретро не совсем похоже.... - Ukrainian Opel Club This thread Refback 22-05-2008 11:09
rwd astra mk3 - Vauxhall Astra Mk3 Owners' Club This thread Refback 25-03-2008 17:32
Surftipps und Empfehlungen This thread Refback 02-10-2007 18:42
Kev Read - PROJECT YB - Page 5 - Astra MK2 Owners Club This thread Refback 16-01-2007 10:12
Der Opel-Sechser Talk :: Thema anzeigen - Kadett Bi-Turbo This thread Refback 14-01-2007 16:17
Members: 43,212
Threads: 310,611
Top Poster: LEE69 (43,149)
