astra mk3 headlining
Results 1 to 8 of 8
Thread: astra mk3 headlining
    Apr 2012
    oxford
    astra gsi mk3
    hi all i have a mk3 astra gsi that needs a new roof lining can you tell me if a four door will fit thanks
    MIGClub Member IanPaskin's Avatar
    Jan 2012
    Shropshire
    MR2 - Astra G
    Nope the b & c pillar are different,
    Apr 2012
    oxford
    astra gsi mk3
    Re: astra mk3 headlining
    not being rude are you 100% sure thanks
    Jan 2012
    Shropshire
    MR2 - Astra G
    Yes I used to work for Johnson controls programming the robots that were used for cutting the roof linings on Astra mk3 and mk4 the b pillar on the 3dr is further back as the door is longer...
    Apr 2012
    oxford
    astra gsi mk3
    Thanks just got told difrent any ideas wot i can do or were get one thanks
    Jan 2012
    Shropshire
    MR2 - Astra G
    For a guess it's sagging? They were made with a piece of ridged foam with fibreglass or hessian sandwiched together... so it has probably delaminated, I have a mate with a 3dr mk3 headlining I will ask if he still requires it,
    If you could find a good solid headlining you could get some material and cover it using spray glue.
    Apr 2012
    oxford
    astra gsi mk3
    yeah sgs realy bad shame its a mint car 2nd owner from new origanal sills arches just roof lets down
    Jan 2012
    Shropshire
    MR2 - Astra G
    Actually seems i was mistaken, i thought about it after and it would have been Mk 4 that we cut with robots so i just dug some old data out and here are the two Hatch headlinings details, first number is the Johnson control number the 90xxx number is Vaushall part,
    163000 90328445 H/L,2700 HTC EMP 2700 Hatch Finished 31998 Vauxhall Motors LTD
    163044 90328557 H/L,2700 S/R EMP 2700 S/R Finished 31998 Vauxhall Motors LTD
