Hi, been gathering parts together over the last few weeks to build my rwd micra. I did fancy doing a mini but there's lots about and are more expensive than a micra to buy with the same amount of rust
Finally found a micra and picked it up last night, didn't plan on getting much time this weekend to make a start but i have had a few hours, managed to stip all bits from inside out i dont need, exhaust and heat shields off, shafts half out, engine and box dropped in one need some more time to get it out tomorrow hopefully. Few pics of car progress today, pics of bits sorted to come.
stripped inside to sell bits i dont need. thinking of keeping carpet door cards full dash etc in.
on patch that needs welding. exhaust and heat shields to be removed more to sell.....
Engine and box nearly out just a few bits to disconnect at the rear and pull loom through. bay should clean up nicely looks like oil leak has protected the bay :face:.
Sprocket and oil/grease can made by Douglas from westgarage engineering. Very well made, all to size a good tight fit and top man, very helpfull.
mx5 lsd shafts and uprights etc. will possibly need a shaft shortening as its about 5" wider than the micra track. should sit flush with arches on standard offset 13" steelys.
