Green Corsa B Track Car Project!
Page 4 of 6 FirstFirst 1 2 3 4 5 6 LastLast
Results 76 to 100 of 149
Thread: Green Corsa B Track Car Project!
  1. #76
    Mar 2010
    Stockport, Cheshire
    Golf Mk4, AstraVan
    Re: Green Corsa B Track Car Project!
    I have used chopped up radiator hose to fill the gaps, seems to work well also. More noise from the engine inside the car though and you can feel the engine running much more!
    “Speed has never killed anyone, suddenly becoming stationary… that’s what gets you.”
    Mar 2011
    Honiton, United Kingdom
    vectra b gsi & Corsa b Xe
    Quote Originally Posted by vantastic007 View Post
    yeah totally agree but stops everything flapping around a bit, so gotta be good...
  4. #78
    Mar 2011
    Managed to clean and shot blast a few more bolts and bracket today.
    Also started sorting the front hubs out:
    Hopefully get too the scrap yeard weekend and grab some vectra b front legs: 288mm front brakes, 5stud hubs. Then ill sort out what bearings to use and machine the front hub carriers.
  5. #79
    Mar 2011
    Cleaned and painted my oil cooler:
    Looks a lot better now.
  6. #80
    Mar 2011
    Bring on the warmer weather so i can get on with the body.
    Decided im gunna re-run all the brake lines, and install a wilwood bias valve to stop the back end looking up with my 256mm rear discs.,
  7. #81
    Mar 2011
    Does anyone know what the brake fittings are on vauxhall??? I can be bothered to check it out myself.. lol
    Thinking they are M10 x 1mm?
  8. #82
    MIGClub Member Corsamitch's Avatar
    Aug 2011
    Surrey
    Tb'd xe corsa
    Quote Originally Posted by banfield297 View Post
    Correct
  9. #83
    Aug 2008
    Perth ecosse
    Red Let
    Nice job on the rear axle.
    I done the same with my engine mounts, it improves gear selection on power and downshifts.
  10. #84
    Mar 2011
    Quote Originally Posted by Corsamitch View Post
    Correct
    Cheers bud...
    Love your Corsa mate, you must be spending some serious cash on that bad boy!!
  11. #85
    Aug 2011
    Surrey
    Tb'd xe corsa
    Cheers mate, try not to think about the money I've spent tbh lol...
  12. #86
    MIGClub Member Th0m45's Avatar
    Mar 2010
    Isle of Lewis
    Astra van & Cavalier SRi
    Looking good mate
    Vauxhall Astra Van 1.7DTi- T22 JFF
    Pre-Facelift Vauxhall Cavalier SRi - J551 AHJ
  13. #87
    Oct 2004
    Oban - West Scotland
    Astra G/Nova TB
    Rear beam looks good!
    Atb diff (automatic torque bias diff) but its obviously std, ad it still had the speedo drive gear.
    Ive also filled rubber mounts with sikaflex/polyurethane sealant (although i smoothed it over, and it looks factory), makes a big difference, keeps the engine solid
  14. #88
    Mar 2011
    Quote Originally Posted by Th0m45 View Post
    Looking good mate
    Cheers Bud
  15. #89
    Mar 2011
    Quote Originally Posted by GaryVaux View Post
    Cheers mate love the beam.
    Yeah the diff still had the speedo ring on it so all was good there! Thanks for the info i thought ATB was a make or summit.. lol
    Harder mounts are always good, are u saying i didnt do a very smooth job of them??? LOL
  16. #90
    Mar 2011
    What a cracking weekend (not that i got too much done on the motor) Hope everyone had a good one!?
    I managed to strip all the brake lines off:
    And remove the tank ready to get the underseal out:
    The tank wasn't in bad nick but ill paint it anyways:
  17. #91
    Mar 2011
    Decided im gunna run copper brake pipe through the car, and use stainless braided hoses in place of the flexies.
  18. #92
    Mar 2011
    Good morning people wondering if anyone has any advice for me?
    I started looking at the wiring last night but a little unsure whats what!?
    Any help would be much appreciated.
    Here's some pics of what plugs i'm unsure of:
    This one I believe I wire colour to colour onto the corsa plugs inside the car?
    Then i guess i just need a main power feed and a switched live to run the ecu????
    Which i think is the right hand plug in this pic?
    Cheers for any help in advance
  19. #93
    Mar 2011
  20. #94
    Aug 2011
    Surrey
    Tb'd xe corsa
  21. #95
    Mar 2011
    Cheers mate looks like a very usefully thread although it talks about 3 plugs where as mine only has 2 black plugs. Lol. I'll have a look at the wires later see if i can make more sense of it.
  22. #96
    Aug 2011
    Surrey
    Tb'd xe corsa
    Read the whole thread mate, it's all in there..
  23. #97
    Mar 2011
    Well its been a while but managed to get a few more bits done
    got the tank cleaned and primed
    finished painting the rear callipers
    Flushed out the gearbox, put it all together ready to fit
  24. #98
    Mar 2011
    Also took all the sound deadening out from the engine bay:
  25. #99
    Mar 2011
    Shot blasted some more bits ready for paint:
  26. #100
    Mar 2011
    Hopefully over the weekend i'll be sorting the brake lines, getting the tank back up, re fitting the rack, and might even manage to get the engine in.......
    Bring on the sun
