**Corsa B RoadTrack Car C20XE on Jenveys**
Page 23 of 26 FirstFirst ... 13 14 15 16 17 18 19 20 21 22 23 24 25 26 LastLast
Results 551 to 575 of 644
Thread: **Corsa B RoadTrack Car C20XE on Jenveys**
  1. #551
    Oct 2008
    west midlands
    combo van
    Re: **Corsa B RoadTrack Car C20XE on Jenveys**
    awesome work mitch i can defo say if you roll that on a track day you will defo walk away with that cage,
    N/A is the way......
    MIGClub Member Corsamitch's Avatar
    Aug 2011
    Surrey
    Tb'd xe corsa
    Cheers dude, and yeah, cage should see me through god forbid there are any mishaps!!
  4. #553
    Oct 2008
    west midlands
    combo van
    How did the guy who done your painting get on mitch was it tricky to do inside and around the cage ?
  5. #554
    Aug 2011
    Surrey
    Tb'd xe corsa
    He said it was an absolute pig lol..
  6. #555
    Oct 2008
    west midlands
    combo van
    Quote Originally Posted by Corsamitch View Post
    I bet it was ive done painting in past and can get tricky, Does look a great job tho spesh like the way you have cut of the white at meeting point of floor looks well good,
    Where did or do you go for your track days mitch ?
  7. #556
    Aug 2011
    Surrey
    Tb'd xe corsa
    Haven't as yet mate, brands hatch will be track of choice though as its only 30 min drive from me. Am planning on doing a fair few hp this year though mate!!
  8. #557
    Dec 2009
    North Lincolnshire
    Corsa XE,Astra SRi-T
    Lookin sweet mate! Keep up the good work
    J22 TYN
  9. #558
    Aug 2011
    Surrey
    Tb'd xe corsa
    Thanks Justyn
  10. #559
    Aug 2011
    Surrey
    Tb'd xe corsa
    So, got a little done over the weekend, sorry for the bad pics, I don't have the best light in my garage..
    First up was to wrap and p clip some of the loom, I say some as I only had certain size p clips so have ordered the size I need and will continue with that next week, the bits I did do..
    Then I test fitted the solid gearbox/engine mounts..
    Then it was onto finishing the dash, I had to chop a little out of the light switch panel in order to fit round the cage..
    And the fuse cover..
    Then mounted hazard light switch and fan switch and fitted..
    Then the gauge pod and fuel level gauge..
    Then the shift light and clock shroud..
    Have sent the surround for the stack dash to be flocked, am really looking forward to its return so as I can fit that and that'll be the dash finished
    Then I fitted the lifeline snap off boss..
    And fitted..
    I did also lower the steering column slightly but no pics of that, is just perfect now though, could do with coming over an inch or so to be central with drivers seat but that vauxhalls shitty build tolerances I guess..
    Then it was the battery box, have relocated this behind the passenger seat as it was in the boot previously, should give a better weight balance here.
    Then I got the drivers seat in, starting to look like a car again now
    Got a real busy week this week so prob not gonna get a play so until next week...
  11. #560
    Oct 2008
    west midlands
    combo van
    Looking good Mitch what's it like to get in and out of the seat ? Also you got much room behind your front engine mount to get a spanner up behind to do mount to block mount up? Mines proper tight
  12. #561
    Aug 2011
    Surrey
    Tb'd xe corsa
    Quote Originally Posted by sneakycorsa View Post
    Its not too bad tbh mate, easier than it looks though haha, snap off boss was essential too.
    Nope, no room at all, it will have to be bolted up to engine then lifted into the chassis mount.
  13. #562
    Feb 2008
    South Central
    Lwb Connect / 2.0 Nova
    I see you turned your side mounts around. Did they still meet the holes ok?
  14. #563
    Aug 2011
    Surrey
    Tb'd xe corsa
    Quote Originally Posted by Craig-S View Post
    I didn't mount them the first time but yeah, mounted the right way now. Yeah mate still met all holes perfectly
  15. #564
    Jul 2009
    great yarmouth
    Cali 2.5 v6 redbull N'95'
    23 pages of pure pleasure, love this corsa congratulation!
  16. #565
    Aug 2011
    Surrey
    Tb'd xe corsa
    Quote Originally Posted by redbull_v6 View Post
    Why thank you very much
  17. #566
    MIGClub Member bigron1988's Avatar
    Aug 2009
    southport
    uks quickest corsa b,10.6
    so how many times have you polished the inside then?
    total vauxhall cover car october 2012, 10.6 sec quater mile@137, uks quickest corsa b
  18. #567
    Aug 2011
    Surrey
    Tb'd xe corsa
    Quote Originally Posted by bigron1988 View Post
    Haha, I haven't and in fact you should be asking, how many times have I scratched it! Lol
  19. #568
    Aug 2011
    Surrey
    Tb'd xe corsa
    Not much of an update but managed to find time and got over to the car to get the carbon front cards on..
    And a couple of deliveries today..
    Protec solid steering rack mounts
    And the fascia for stack dash is back from flocking
    Test fit
    Hopefully get to fit it this weekend, if I'm not working
  20. #569
    Aug 2011
    Surrey
    Tb'd xe corsa
    Got a little bit done today..
    Got all the inside loom completely covered and clipped, looks much better, running along passenger side sill..
    Around the rear arch..
    And along the boot..
    With that now finished, was onto the solid steering rack mounts, really nice and easy to fit!
    Then it was onto the dash, spent what felt like hours chopping out all the wires for the standard clocks, keeping the few wires I needed and joining up to the stack loom, really tight fit with it all behind the dash but its in and should hopefully work, am pretty confident I got all the wires right but you know how it is lol. Also wired in the fuel gauge at the same time. Am planning to finish all the wiring next, earths etc so as I can test it.
    The 4 switches for the display mounted..
    And the display..
    And my view
    Should hopefully get a few hours this week, am on jury service from tomoz but shouldn't be as long days as what I do at work..
  21. #570
    MIGClub Member corsadonk's Avatar
    Jan 2009
    Wiltshire
    Corsa C Z20LET
    I think your Brother needs to give his bike to a good home.
    All looks very tidy.
  22. #571
    Aug 2011
    Surrey
    Tb'd xe corsa
    Quote Originally Posted by corsadonk View Post
    Cheers mike!
    Haha, he needs to do something with it, it's a good 3-4k's worth of bike, never rides it, in fact I can probably count on my hands the amount of times iv seen him ride it! Got a sat nav and everything on it!
  23. #572
    Oct 2007
    Bulgaria, 1574 Sofia
    Opel Vectra C20XE
    Fantastic work!
    Opel Motorsport
  24. #573
    Apr 2008
    Droylsden
    Corsa D Sri & Nova 2.0
    nice tidy work pal, how much were those rack brackets and will they stiffen the steering up?
  25. #574
    Aug 2011
    Surrey
    Tb'd xe corsa
    Quote Originally Posted by Zender View Post
    Fantastic work!
    Cheers
    Quote Originally Posted by thedjse View Post
    Cheers buddy! Rack mounts were £58 from protec. The mounts will reduce any play that would have been caused by the standard rubber mounts.
  26. #575
    Aug 2011
    Surrey
    Tb'd xe corsa
    This little lot turned up yesterday, and will be getting fitted along with the swirl pot tomoz
    Facet red top (lift pump)
    2x mini bullet filters
    -6 fittings
    -6 braided nylon ptfe fuel hose
    P clips
    Also have a 1.5 diesel corsa b fuel tank cage on its way to me as it doesn't house the fuel pump but has the pick up pipe in tank which is what I now need.
    More updates tomoz
