my corsa c20xe project advise needed. lots pics.
Results 1 to 24 of 24
Thread: my corsa c20xe project advise needed. lots pics.
    Dec 2010
    Hastings
    A lot of cars
    Hello right i am guna start of with i am not a grate speller. I no this i dont need to be told. you should be able to get the gist of what i am trying to say. I have a corsa 1.2 8V witch i have been converting to a c20xe, witch i took out of my rusty corsa gsi with the engine fitted. I striped out the gsi with what i belive i will need but any one think i may need any thing els pleas let me no as im not 100% my 1.2 has no power steering and what to keep it that way but the redtop engine has power steering pump and belt i dont no were or how i can change it to the single V belt? Any help with were to the the bis for that would be grate.
    I striped the engine and gearbox with drive shafts suspention and ARB all attatched and then just lifted it in to the new car. the power steering belt it caching on the left top engine mount. I dont have a pic of this will get one tomorrow. I think i have the right mounts i brought new ones from ebay as my other shell was the gsi witch is type 2 i belive. Or the other way around. The wiering from the gsi was all sniped so i will have to just snip the wire from the 1.2 i have a conversion guide but its all ways help full for any one els to help. Also is the 1.2 8v fuel pump good enough? i have the one from the gsi so its ok if not just easyer i have all ready swaped the fule lines ends so it fits on the fuel rail.
    I have done quite abit to this and still needs quit abit more but i have sorta stall with it and need some advise so i no what i need to do for the rest. also the break lines behind the power cap are to close and touch do i need to run new ones? i was guna replace with copper so not touching but i dont no if i can move engine foward or any thIing?
    I started to strenthen the chassi and i have the strenthening kit witch i am goin to fit after its all up and running as i thort main thing was get it running first. Also what bits would i need of the gsi shell i have the hole car witch will be goin to scrap very soon and want to get all the bits of it first. So any one needing parts or no of parts i may need let me no
    How i got the car.
    IMG]http://i468.photobucket.com/albums/rr44/me9997/c20xe%20conversion/IMG_0111.jpg[/IMG]
    Then started striping
    Also have a nice suprice i will like to be adding.
    Hears a few bits i have for it
    I have this but am unsure if to put it in think will weigh it down to much
    Any advise welcome any help would be greate Let me no what you all think and some advise on finishing it and what bits i would need of my gsi shell would be grate Thanks Connor
    Never trust the judgement of a 4WD owner... Big brake kits are for people with commitment issues... Stock......... isnt that soup or something...
    South East Regional Co-ordinator
    Apr 2011
    Sheerness, Kent.
    2003 Arden Zafira GSi
    Re: my corsa c20xe project advise needed. lots pics.
    That's a nice instal...but the look is now "less is more". Leave the rear stripped out IMO.
    Welcome to the jungle we've got fun and games.
    Sep 2004
    Nottingham M1 J26
    911. Loves: Dirty sluts.
    I'd love to help on the conversion but your spelling makes it too hard to read. Spell checkers are free and would fix your problem.
    Sep 2011
    essex
    Astra sri
    like Ardenblueroy said leave the back striped out will look much better
    INSTALLING SUMMER... ████████░░░░░░░░44% DONE. Installation failed.
    404 error: Season not found.
    Dec 2010
    Hastings
    A lot of cars
    Quote Originally Posted by Ardenblueroy View Post
    This is what i was thinking maby roll cage as will be using the NOZ. But wernt to sure if would be good with that. Thanks
    Dec 2010
    Hastings
    A lot of cars
    Quote Originally Posted by Nemesis View Post
    Hello right I am going to start of with I am not a grate speller. I no this I don't need to be told. You should be able to get the gist of what I am trying to say. I have a Corsa 1.2 8V witch I have been converting to a c20xe, witch I took out of my rusty corsa gsi with the engine fitted. I striped out the gsi with what I believe I will need but any one think I may need any thing else pleas let me no as IM not 100% my 1.2 has no power steering and what to keep it that way but the redtop engine has power steering pump and belt I don't no were or how I can change it to the single V belt? Any help with were to the the bit's for that would be grate.
    I striped the engine and gearbox with drive shafts suspension and ARB all attached and then just lifted it in to the new car. The power steering belt it caching on the left top engine mount. I don't have a pic of this will get one tomorrow. I think I have the right mounts I brought new ones from eBay as my other shell was the gsi witch is type 2 I believe. Or the other way around. The wiring from the gsi was all sniped so I will have to just snip the wire from the 1.2 I have a conversion guide but its all ways help full for any one else to help. Also is the 1.2 8v fuel pump good enough? I have the one from the gsi so its OK if not just easier I have all ready swapped the fuel lines ends so it fits on the fuel rail.
    I have done quite a bit to this and still needs quit a bit more but I have sort of stall with it and need some advise so I no what I need to do for the rest. Also the break lines behind the power cap are to close and touch do I need to run new ones? I was going to replace with copper so not touching but I don't no if I can move engine forward or any thing?
    I started to strengthen the chassis and I have the strengthening kit witch I am going to fit after its all up and running as I thought main thing was get it running first. Also what bits would I need of the gsi shell I have the hole car witch will be going to scrap very soon and want to get all the bits of it first. So any one needing parts or no of parts I may need let me no
    Hope this is better? Thanks
    Jan 2008
    Lancishire/Manchester
    Piaggio/Corsa/Honda CBR
    nice work there leave the install n sell it to add funds to the build
    Just bring me Tea & Biscuits an a ciggarette............ nothing more....
    Corsa GSi Long Term Project >> http://www.migweb.co.uk/forums/proje...project-9.html
    Dec 2010
    Hastings
    A lot of cars
    Quote Originally Posted by Todi-Corsa View Post
    I am in half minds if i want to sell it or not what would you think some thing like that is worth?
    Looks like a nice start to your project.
    Are you building the car to be a "racer" or a everything car? Will you have rear seats? Google Chrome browser has a build in spell check which is very good.. I know i use it..lol
    Dec 2010
    Hastings
    A lot of cars
    I mite have to download it Thanks. I want it as a weekend car really but not sure if I going to have rear seats in it or not. I don't think i will. I want it as a fast road car witch would like to take to track days with my brother.
    Sell the install then. Use that money for a cage.
    Dec 2010
    Hastings
    A lot of cars
    What do you think some thing like that is worth? Very well done behind the seats is all leather ect looks spot on. The subs are really really good blew the window out! sounds grate.
    Jan 2008
    Quote Originally Posted by me9997 View Post
    Tbh mate it will be worth whatever people are willing to pay, price stuff up using ebay and see what others are selling at
    Keep up the good work
    Sep 2009
    Isle of lewis
    Cavalier turbo, mk2 golf
    good wee project mate
    was gona say tho i think you need a bigger jack eh
    No clue, not a huge install kinda guy, use the "what's it worth" forum.
    Dec 2010
    Hastings
    A lot of cars
    I will try that thanks Any one with any advise of what i may need of the gsi for the 1.2? also some of the few bits i need help with any one no? Thanks Coonnor
    Dec 2010
    Hastings
    A lot of cars
    Hello this is what I need help with most. I need to use a single V belt with out power steering pump. As this hits the mount. I dont need the power steering as i have a no power steering rack. I was just going to loop the power steering pump around since i couldnt find a single v belt and pullys. Any help with were i can get single v belt for this engine or any other waya round this? Thanks Connor Hears the pic's
    Dec 2010
    Hastings
    A lot of cars
    Any one with any idears of were to get the single v belt? Or any way i can get around my problem with this? Thanks
    Dec 2010
    Hastings
    A lot of cars
    Right I started to strip it out as I have a leek some were and as you can see gone very moldy and have big puddles in the car. While I was there thought would be a good time to take sound deadening out as well. Hears a few pics. Also a few pics of my old daily driver until some one crashed in to the rear and unsure what's going on so pics of new daily driver I no not a Vauxhall!!
    All of it come off very easy no heat needed I think was due to the water soaking in to it some bits just hit with a small hammer and chunks come off. Other bits just use screwdriver
    Old one waiting for insruance company to sort out.
    And what i am driving in the mean time come up very cheap so brought it as a run about
    I no
    Feb 2008
    salisbury
    Transit / 2.0 Nova
    I no
    If you put that 206 back to standard it would raise a few hundred pounds selling the morettes, sp mesh, mirrors and wheels.
    And you would be left still with a great daily driver.
    Dec 2010
    Hastings
    A lot of cars
    Quote Originally Posted by 8valve-craig View Post
    Yer I no the lights and bits are worth a few bob but dont wana be messing about looking for bit to replace the bits i take off and dont realy have the time money not a grate problem for me so mite as well leave it and sell after im finished. If that all makes sence? If i every need money i have so many car parts and bike parts i just chuck them on ebay and sell a few bits or run a few scrap cars in. thanks tho pal
    Jan 2008
    brake servo hole is a nice place where leaks come through, it did on mine like a little river sometimes in heavy rain
    Dec 2010
    Hastings
    A lot of cars
    Thanks mate will have a little look and see if I can see any were.
    Jan 2008
    no probs, also worth a check is the inlet into the bay for the heater matrix, also check that all the rubber grommits in the bulkhead for the looms etc haven't popped out.
    most likely culprit is the brake servo hole into the cabin like I said, the seal usually perish usually caused buy water drain off channels becoming blocked up with muck n rotting the rubberised foam gasket sat between the bottom of the servo and the hole
    get a mate to get a hose pipe on the car n see if you can spot where its coming in
