After I cooked my Mk3 GSi on a trackday I decided I wanted something a bit newer. I'd been driving my girlfriends 2.2 coupe and quite liked it so decided a Mk4 was the way forward. Only had one thing I was sure of, I wanted a Z20LET so started looking at Coupe turbos first then remembered SRi turbos
Found one with low mileage, lots of history and receipts and checked to see if it was HPI clear. Had a VXR turbo fitted and had the stem seals recently done and looked like a decent car. Everything seemed fine so went to have a look. It drove fine when I tested it but was cold and icy so was a short test. Started it from cold and it had no knocking, smoking or anything else so agreed a price and took it away. Half way home when I got onto the motorway it started popping and farting at around 70 MPH...great. I work for Vauxhall so wasn't worried and spent years with a C20LET in my GTE so misfires I'm used to. I plugged it into tech2 at work and it seemed to be the boost control solenoid so replaced that and it did nothing...not going to be as easy as I thought
The running issues are weird...it drives fine round town and on the back lanes. Get it on the motorway at 70 MPH and it runs like a pig, pops, farts and hesitates when you try to speed up. It does crap MPG, average over a few weeks was 22. It can run fine for days then for no reason start misfiring again. It also turns off the traction control and ABS, when it does this (which is most of the time now) it won't idle properly either, even stalling at times. I thought it was a crap remap that was at fault but that turned out not to be the cause
To do list...this'll no doubt get bigger though as I find things
Mechanical
Remove shonky remap - Checked 20/12/11. According to Tech2 has factory map installed but still manages to run rich and at 15 PSI?
Oil leak from rocker gasket
Oil leak from front breather pipe
Turbo missing stud. Doesn't blow or affect performance for the time being
Crossover pipe needs replacing/repairing
Tidy up...a few wires & cables from old stereo need taking out and could do with a set of hoses
Tracking
Body
Paint front bumper (scratches & chips) and fit new mesh
paint side skirts
Replace wheel arch liners
New griffin boot badge - Done 20/12/11
New turbo badge (undecided yet?) - Done 11/01/12
Paint wheels
Fix dents on NSR quarter and boot lid
Interior
New front drivers seat and valet the rest
Swap cheap crappy boost gauge. It blinds you at night and I'm not convinced it tells the truth - Done 20/12/11, trusty Power Engineering gauge fitted
Replace steering wheel - Done 11/01/12, all black leather turbo wheel
First job was to get rid of the front grill
20/12/2011...
The misfire saga is ongoing, Tech2 says I have the latest factory map installed...my boost gauge says I'm running 15 PSI and my car smells like it's running rich...Tech2 says it's running rich too. need to trace the vac hose to make sue it's not kinked and giving a false reading. It always read correctly in my GTE
...I'm more confused than when I started. Is it only running rich because the boost is blowing the spark out and the fuel isn't getting burned properly? The only way I'll know is to get it on a rolling road and check it properly so that's the next job
Took time out of trying to work that out and fitted the boot badge I'd ordered and swapped the boost gauge for an old Power Engineering one I ran in my GTE turbo and was always accurate and doesn't light the interior up. The idea of getting an SRi-T in the first place was for it to be a bit of a sleeper and not stand out too much. You can't really do that when you've got a gauge in your face that lights you up bright blue so you look like something off Avatar driving down the road.
Thankfully it was easy enough and just need to wire in the backlight and it's good to go. The boot badge was easy enough, the only issue was one of the previous owners had super glued a new style Vaux griffin on but the replacement covered most of it up and it doesn't show too much unless you're looking for it. The other badges have all been taken off and will be staying off apart from the turbo one which I've not decided on yet...yes or no?
10/01/2012
Been busy stripping my Mk3 so not had the time to sort the SRi but still been shopping for a few bits for it
New rocker gasket set to sort the leak, bought genuine as I've bought none-gen before only for them to last a few weeks then start leaking again. I was going to leave the turbo badge off for the sleeper look but seeing as I can't go anywhere without some retard driving 2 inch off my arse it looks like the sleeper idea has fallen flat on it's arse
Mine had a none turbo leather wheel fitted for some reason so I've been looking for a replacement for a while and this turned up in ebay. Stuck a bid on, forgot about it then saw i'd won it for 40 quid...bargain
11/01/2012
Wheel and badge fitted but as usual nothing goes to plan...
Badge was easy enough, quick wipe down with panel wipe and warmed it up and stuck it on (...pics to follow). The steering wheel was a different story. First turns out the tracking is out and whoever fitted the other wheel didn't bother to use the marks to line it up so that's another job for the list. Another thing that came up was when I reconnected the battery and started the car, it wouldn't idle and kept stalling. Kept it running long enough and it eventually it would idle on it's own but still lumpy.
Plugged Tech2 in again to see what codes would come up after it was cleared last time and we got new codes that I've not had before...
P0100 - Mass or volume air flow circuit high output
P1106 - Boost pressure control device malfunction
Air flow meter was replaced last August and the front boost control solenoid last month. Cleared them again, car running fine and left work...got a mile down the road and the traction light came on again and the crap idle came back. The earth repair is the first job, I'm hoping that the fact it throws up different codes is pointing towards a wiring fault. Once that's checked it's a case of eliminating everything else
I've also found out this car has had issues for a long time
Daz's Mk4 Sri-T - Astra Sport and Astra Owners Club - Mk1 | Mk2 | Mk3 | Mk4 | Mk5 | Mk6 | Astra Van | 888 | VXR - All Welcome
From what I've found out so far it's not got a remap, has had the same issues for at least a year and after this guy had it it went to a bell end that bodged it and sold it on
I thought it had a snapped manifold stud, turned out they couldn't be bothered to fit it. Thought the cool running stat wasn't helping, turned out it didn't have a thermostat fitted at all so wasn't getting up to temp...even worse in December. Believe it or not there is a decent car under all the shonky workmanship, just taking a while to find it.
