My Mk4 Astra SRi
Results 1 to 18 of 18
Thread: My Mk4 Astra SRi
    MIGClub Member elongmoss's Avatar
    Jun 2011
    Burton-on-Trent
    3L V6 Mk4 Astra
    My Mk4 Astra SRi
    Not going to be the greatest project thread of all time but i thought i would share what i have been up to with you all
    Hears the starting point a 2000 White Mk 4 Astra SRi 2L Ecotec Engine.
    Uploaded with ImageShack.us
    I have owned this car since 2005 and in that time have covered nearly 60000 miles however with fuel costs decided to get myself a diesel as i commute over 500miles a week.
    However some sort of sentimental decision ment no matter what i just couldnt come to get rid of my astra so with no MOT or tax and been sat for over a year and a half i decided to take her round the back and give her a good sorting out!
    1st stop give the old wheels a new lease of life
    Shot blasted and powder coated in white to match the car
    and even got the lowering springs sprayed up to match
    whilst i was on a painting mission i replaced the drivers door handle with a rear offside one from the scrappy so to remove the lock hole and then colour coded them both
    After all the exterior work i gave the insides a good clean and decided to replace the rear grab handles with the illuminated ones again a scrappy bargain (theres a theme hear)
    After all that hard work and reading up on some project threads on hear i decided to take the plunge and:
    Whipped the Engine Out!
    Wasnt quite sure yet on what i was going to replace it with? it was either going to be C20XE or X20LET both quite expensive to source a good one.
    But then this showed up
    X30XE from an MV6 Omega Ex Police interceptor 3L V6 Power
    i had to strip it out myself from the car sat on the blokes front lawn (not good when using an engine crane) but the car had 178000 miles on it however had a recipt from the force for the replacement engine at 86500 miles so new engine had less than 100000 miles on it Bounus it was a steal at £150!
    Sat next to the car waiting to go in.
    however i have to sort a few bits first on the list are
    From the X25XE
    inlet plenums
    sump
    sensors and ECU inc key chip
    offside 2 piece driveshaft (to reduce tourqe steer)
    and loads of various hoses belts and bits and bobs to bolt it all together
    More Soon
    If at first you dont succeed... CHEAT!
    Jun 2011
    Burton-on-Trent
    3L V6 Mk4 Astra
    Re: My Mk4 Astra SRi
    Well got all bits sourced and shes up and running
    i have litterally just thrown it all together to get her running as quickly as possible just using the standard F23 box and original shafts athough i have uprated the brakes to 308mm disks and pads from a coupe turbo.
    taken her out for a few test runs 1st up the Stowe circuit at silverstone for a track day
    Then down Santa Pod for a RWYB day
    Didnt do too badly handled well at Silverstone despite all the extra weight up front and some respectable times at Santa Pod.
    The only problem is trying to put all that power and tourqe down in one go just spins up the tyres, even pulling off in the wet is nearly impossible
    So with much thought:
    Shes off the road again although only tempoary as waiting to get these bits and pieces fitted-
    Split Driveshaft that never got fitted the first time
    Set of coilovers for the front to cope with the extra weight
    Replacement Gearbox old ones fine but need something to put this in
    Quaife F23 ATB limited slip differential should sort out putting the power down nicely
    So whilst its coming apart i thought i would do a touch of painting to smarten it all up a bit
    inlets and plenums all painted up
    new gearbox with the quaife fitted all painted up ready to go
    Update coming soon once i start getting it all back together
    Sep 2011
    essex
    Astra sri
    kool project there. nice to see another person that dont mess about putting engines together and scared to touch them
    INSTALLING SUMMER... ████████░░░░░░░░44% DONE. Installation failed.
    404 error: Season not found.
    Aug 2008
    rotherham
    nova
    looks nice are you going to spray the black parts on the car white ?
    East Mids Regional Co-ordinator simonsri's Avatar
    Dec 2010
    Chesterfield
    Vectra Sri 150
    Looking good there mate, would like to see the rwyb day then after all this work.
    MIGClub Member vauxal's Avatar
    Feb 2005
    cwmbran/swansea
    C20let Astra van
    Awsome project .
    Jun 2011
    Burton-on-Trent
    3L V6 Mk4 Astra
    Cheers all glad you like it there may be some white irmscher skirts too add too but not sure on them yet im going to get engine sorted first
    Nice white..lol, nice project. Should be fun on track..
    Feb 2002
    Fareham, Hants.
    13S C20XE X20XEV
    Lovely, nice to see a V6 in a Mk4; not seen too many yet.
    They're there, in their room.
    Dec 2002
    Essex
    Lada Riva
    14.7 .... not bad , looks aieet .
    Jun 2011
    Burton-on-Trent
    3L V6 Mk4 Astra
    Well a little update for today the engine is out again
    And Gearbox is off
    And just thought i would share how i have done the engine mounts incase anyone else is looking to do this type of conversion
    Front engine to subframe mount just using angle iron and the original omega engine rubber mount
    Stabiliser bar mount using the original astra engine mount small piece of angle iron and some spacer bars
    And then the auxiliary belt layout
    i have removed the Power steering pump as the astra is electric pump and the air con pump to make life easier then used a belt from a 3 cyl corsa i think as just went wandering round the scrappy till i found one the right length also the tensioner pully is a smaller one from a saab i think.
    More soon
    Jun 2008
    Newcastle Upon Tyne
    Impreza + Astra SRI
    Great project
    Jun 2011
    Burton-on-Trent
    3L V6 Mk4 Astra
    Just a quick pic from my play on the local sprint course last sunday
    would have had more but my old man showed up late so only caught me on the last run
    oh and for those that noticed i have added a carbon bonnet (yes its not a wrap)
    hear it is waiting to be fitted
    Dec 2010
    Chesterfield
    Vectra Sri 150
    Nice we should do something like that as a club where was it at mate?
    Vauxhall, Once Driven Forever Smitten
    Jun 2011
    Burton-on-Trent
    3L V6 Mk4 Astra
    Curborough sprint course between Fradley and Litchfield
    Hears the Link
    Introduction to Sprinting Day
    Flyered a few vauxhalls as well whilst was there but TBH it was mostly a MX5 and Scooby day out got some funny looks as rolled past in my astra
    but lots of questions after running
    Sep 2004
    Nottingham M1 J26
    911. Loves: Dirty sluts.
    Car is looking great Gaz and coming along really well!
    Oct 2008
    beverley, near hull
    astra mk4 van v6
    hi mate just wondered if you still had your v6 in astra, i have a 3.0 in a van and its been runnning for ages but just skips a beat now and again, you no all off your blue vacuuming pipes to plenium acuators just wondered where u had them piped up to.
    if you could help would be great
    cheers carl
    Jun 2011
    Burton-on-Trent
    3L V6 Mk4 Astra
    FPR goes to throttle body and two flap actuators on the right go to the connection on the rear intake plenum
    should be able to see it hear
    http://img689.imageshack.us/img689/8366/img01861o.jpg
