Opel Astra G X20XER project
Results 1 to 10 of 10
Thread: Opel Astra G X20XER project
    Dec 2011
    Opel Astra G OPC (X20XER)
    Hello everyone ... I present the improved atmo engine X20XER.
    let's start with pictures and descriptions from the start of the project.
    X20XER (160 hp)
    processing and improve flow cylinder head , 5 / 10 mm planing - Increase of compression
    processing and improve Manifold exhaust
    engine block X20XER
    Arp Bolts
    Lightweight Steel Billet Flywheels with 8 bolts
    Alloy Bottom Pulley
    X20XER oil pump is rotor type similar to z20let motor
    C20XE oil pump
    Transmission F18 Cr 3,74 gear box with Quaife ATB Helical LSD differential
    Dbilas Throttle body kit for street
    Standard OPC Camshafts X20XER
    Specifications:
    Duration @ 0.1mm = 265°
    Duration @ 1mm = 227°
    Lift @ TDC 110° = 1.35mm
    Maximum Lift = 10.6mm
    final stage of assembly
    With standard intake manifold
    for any newer update will be…..
    Dec 2011
    Re: Opel Astra G X20XER project
    first Dyno test on Maha LPS 300 PKW
    Specs :
    stock map.
    stock cams.
    stock intake manifold.
    stock exhaust 48 mm
    petrol 95 RON
    Engine Power 170,8 BHP @ 7100 RPM
    Wheel Power 129,6 BHP
    Max Torque 193,9 Nm @ 4200 RPM
    Max RPM 7540
    Oct 2004
    Oban - West Scotland
    Astra G/Nova TB
    Interesting choice of engine, and great power figure!!
    Sep 2004
    Greece
    tigra/LET westfield
    And hopefully more promising in the future graet built there Johny
    MIG.....Made In Greece LOL
    Dec 2011
    Update!!
    63,5 foul exhaust system
    Dbilas throttle bodies
    Twister Filter System 80 mm
    ECU Reflash on the Dyno ( Dynojet)
    192,5 Ps
    210 Nm flywheel torque
    with stock xer's cams!!
    Sep 2004
    Greece
    tigra/LET westfield
    Well done for stock cams!!!!! cant wait to see the future mods!
    But like said you should be very satisfied with the results!
    Mar 2009
    Paris Neighbourhood
    OPEL
    NICE JOB i must say you went from stock XER to the stock Z20LET power , nice , more torque might be a future work on progress plan , but very nice .
    Dec 2010
    Greece
    Corsa C
    Hi Johny, nice project, this power came from stock map ecu???, it's weird! I'm building x20xev with some goodies, like XER cams, exhaust manifold etc but I'll go to Megasquirt way, the stock ecu doesn't seem to has futures to run those cams. Maybe I put some throttle bodies to see power like yours!
    anyway, I like your project, keep tuning
    Dec 2011
    The siemens simtec 70 ecu from x20xev / xer. can easily upgrade the map ... no problem!
    you need to install the program from xer and then adjust the settings on your engine
    Sep 2011
    essex
    Astra sri
    great thread, very nicely done
    INSTALLING SUMMER... ████████░░░░░░░░44% DONE. Installation failed.
    404 error: Season not found.
