My Arden Project: winter rebuild!
Page 2 of 2 FirstFirst 1 2
Results 26 to 42 of 42
Thread: My Arden Project: winter rebuild!
  1. #26
    Jun 2009
    kent
    2.0 Corsa b
    Re: My Arden Project: winter rebuild!
    I know davey was pretty gutted to tbh. Wasent even ment to be in there in the first place lol.
    Iv got autosprint 288 cams. They made a world of a difference, there pretty big so can imagine what it idles like lol. But I couldn't fault them anymore than that.
    How do you mean Darren? When I ha to mod the arches to fit the wheels or what I'm doing now with filling the engine bay arch holes in?
    Jun 2009
    kent
    2.0 Corsa b
    Had some parcels turn up this morning.
    Water proof and breathable carcover,
    And the hoses I ordered and had to send back to have made in black,
    Thursday my friend and I started doing abit of welding, mainly just some little holes and other little cover ups that won't be needed. Also got some chassis plates in but forgot to get pictures so will get some later on.
    First of all dash had to be removed,
    Then welding began,
    Still need to
    - Cut half the bulk head out and weld a new part in
    - weld some more holes up
    - make templates for the arches and ac hole
    - cut some more lugs of and weld over
    - weld in arches and ac cover
    Then on to prepping it all!
  4. #28
    pie
    pie is offline
    May 2009
    blackwood
    Cavalier GSI 4x4
    looking good fella
  5. #29
    Are you going smooth bay then?
  6. #30
    Jun 2009
    kent
    2.0 Corsa b
    Yea smooth bay bud. Not as smooth as yours tho, as in a Corsa it's a pig as it is lol.
    Made some templates for the passages side today
    What a ass of a job!
    Got dark so didn't get any pics of them sat in the rough place.
  7. #31
    Nov 2005
    Chester - North West
    Vectra C CDTI
    loved the car before and going to be a good project
  8. #32
    Jun 2009
    kent
    2.0 Corsa b
    Cheers mate
    Done a little bit today
    Just got all the old seam sealer off and ground a few other bits off and down abit.
    Still need a fair bit a welding to do. Then once that's all out of the way I can start fillering it all in.
    Ground the hooks off from here as they won't be needed
    Still need to weld up this massive mess lol
  9. #33
    Oct 2011
    Corsa B 16v Envoy
    that's a stunning car!
  10. #34
    MIGWeb Lord
    Nov 2009
    Coventry & Plymouth
    Corsa C20LET/Astra coupe
    looking good what did you use to get the seam sealer off with as that stuffs as hard to get off as chewing gum in your hair
  11. #35
    MIGClub Member bigron1988's Avatar
    Aug 2009
    southport
    570.6bhp corsa @1.9bar
    Quote Originally Posted by dewismotorsport View Post
    wire wheel on a drill worked for me
    carbon clad corsa gsi ,c20let big power build thread
    http://www.migweb.co.uk/forums/proje...lots-pics.html
  12. #36
    Jun 2009
    kent
    2.0 Corsa b
    Flat head screwdriver lol took a fair while tho.
  13. #37
    TV feature looks great dude.
  14. #38
    Quote Originally Posted by kizzacorsab View Post
    Pfft, it's not really easy in anything.. That what makes them amazing.
  15. #39
    Jun 2009
    kent
    2.0 Corsa b
    Yea just seen the feature, it's a lot better than the fastcar one so Im happy
  16. #40
    Oh bugger i haven't seen that one.
  17. #41
    Jun 2009
    kent
    2.0 Corsa b
    Been a while since I last updated
    Had some parts turn up
    Then made new templates because I didn't like the other ones I made before
    Cut out then welded in
    Cut out for induction tube
    Welded along here
    Grinded some welds
    1st fiberglass and filler skim
    Sanded down and 2nd fiberglass and filler skim
    Small list of things to do
    Make template for ac
    Make template for inner arches
    Remove bonnet stay
    Weld up brake servo hole
    Weld up breath hole
    Weld up loom hole
    Weld in bulkhead
    Weld up brake hole in bulkhead
    Rust treat rust
    Sand and fill remaning scratches and holes*
    Seam sealer front member
    Seam seal around seals
    Seam seal under arches
    Stopper all filler work
    Underseal front member
    Project thread:
    http://www.migweb.co.uk/forums/projects-restorations/484746-my-arden-project-winter-rebuild.html
  18. #42
    Oct 2004
    Oban - West Scotland
    Astra G/Nova TB
    Have seen this on png (i think) Some real effort gone into it, the bay will look brilliant once complete.
