mk3 astra van saab turbo
Results 1 to 19 of 19
Thread: mk3 astra van saab turbo
    Mar 2009
    newcastle
    corsa xe
    hello this is my little project mk3 astra van had it about a year now its in red with gsi front bumper and bonnet lowerd on tigra alloys (hate them) i have a set of cav gsi wheels (slabs) for it. As for the engine i used the c20xe down york race way a few times 14.9 was the best out the old shed and also off a few sets of traffic lights (private road) i pulled the van off the road due to tax and test and supplied and fitted the xe in to a m8's corsa b (arden blue) so with a rolling shell the plans are tidy OSR arch gone on the lip, strip what i dont need,sort engine bay, get cradle shot blasted then powdercoated new arms,drop links,track rod ends,paint bits then fitt the b204 motor get it running help from astranige (cheers) stage 2 for now ebay intercooler then go from there realy will up load pics soon cheers.
    Mar 2009
    newcastle
    corsa xe
    Re: mk3 astra van saab turbo
    can any tell me what i need to do to upload pics cheers.
    rc
    rc is offline
    MIGClub Member rc's Avatar
    Jan 2007
    Felixstowe, suffolk!
    359.9bhp astra
    sounds a good project
    Mar 2009
    newcastle
    corsa xe
    cheers m8 av got a cuple of pics on my comp just cannit get them on lol
    Mar 2009
    newcastle
    corsa xe
    [/IMG]
    Mar 2009
    newcastle
    corsa xe
    [/IMG]
    [/IMG]
    [/IMG]
    Mar 2009
    newcastle
    corsa xe
    http://img853.imageshack.us/img853/2792/20572010150286946717977.jpg[/IMG]
    [/IMG]
    Here the corsa that ended up with the c20xe
    [/IMG]
    Got this new cooler yesterday with two 90deg bends nice ans shiny
    [/IMG]
    I have also got theys sitting about doing nothing av got a braided feed but wrong ends! so going to ring WON and order nylon feed to suit the WON solinoid.
    [/IMG]
    A mate of mine shined it up a little for me as it was ruff
    [/IMG]
    May 2011
    nice project mate i have done one aswell but 2.3
    Mar 2009
    newcastle
    corsa xe
    Hello m8 cheers for comment would like to see yours I will be up loading more pics soon keep looking cheers agin bud
    Mar 2009
    newcastle
    corsa xe
    Here a pic of the cradle befor blasting !
    [/IMG]
    and the pic after blasting
    [/IMG]
    now just waiting on powder coater to say its done then get the brand new arms and painted anti-roll bar and the new drop links then refit as one unit.
    Got over the garage the day just to see were the cooler is going to sit, looks good will hardly see it with the number plate on will take it off for better airflow on trackdays.
    [/IMG]
    Jun 2008
    co.durham
    mk4 astra bertone coupe
    looking good! how you going about the wiring and which engine you using? b204/234?? removing the immobiliser from the ecu via t5 suite or are you wiring it in?
    Mar 2009
    newcastle
    corsa xe
    B204 mate and Nigel has sorted wirring and a stage 2 map off the t5 suite looking forward to it up and going
    Mar 2009
    newcastle
    corsa xe
    Right havnt been on for a while been moving unit and couldnt get the van moved due to the powerder coater having the cradle so av got it back in black no cash swapped just a bottle of wiskey sorted now the van is at the new unit i can start some more work right so i have got the van at the unit along with the engine, ecu thats had stage 2 and the mods to get it running also got the wirring of nige sitting ready to go the plan is to fit engine get all pipe's to fit fuel,water,oil ect tidy wirring take it all back out get the bay painted get it looking fresh then refit all and paint a few bits and bobbs little bit cleaning to make it look half decent and that will be that side of the van just about done.
    just got it back.
    [/IMG]
    [IMG][/IMG]
    new bottom arms,track rod ends and drop links to fit
    [IMG][/IMG]
    top view
    [IMG][/IMG]
    wirring and ECU
    [IMG][/IMG]
    Engine pic 1
    [IMG][/IMG]
    Engine pic 2
    [IMG][/IMG]
    Engine pic 3 with one of its new bits of pipe to see were it will ruffly be.
    [IMG][/IMG]
    As for the engine going to get a new rocker cover gasket has a slight leak also service with good plugs,oil+filter and a cupple of vacuums split to sort no real problems will update with pics soon cheers for looking.
    Regional Co-ordinator nige-p's Avatar
    Jan 2005
    Moreton, Wirral, United
    saab astra mk3
    glad all the bits got to you any problems with the wiring let me know
    Mar 2009
    newcastle
    corsa xe
    Cheers for the back up m8 super star lol al get some more pics up soon cheers agin bud
    Mar 2009
    newcastle
    corsa xe
    right spent a few hours on the van getting engine in and a few bits and bobbs sorted throttle cable,intercooler mounted and sort sum pipe work out got from top hat to cooler done need to order 180deg bend for turbo side of cooler also need to pick a lenth of fuel hose up to make up not a hard job also spent £30 on two relays needed for my loom/fusebox so few bits sorted pic to follow
    [IMG][/IMG]
    [IMG][/IMG]
    XE cable
    [IMG][/IMG]
    saab cable
    [IMG][/IMG]
    Engine pic again
    [IMG][/IMG]
    relays
    [IMG][/IMG]
    relays fitted
    [IMG][/IMG]
    cooler fitted
    [IMG][/IMG]
    agin
    [IMG][/IMG]
    now made cooler pipe route this way
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    [IMG][/IMG]
    the way i left it fav pic
    [IMG][/IMG]
    down pipe is on need to mate the down pipe to the xe's ss system thats will on no centre box just a back box will get pics soon as cheere
    May 2011
    looking good mate try the rad in next are u using a saab 900 ?
    rc
    rc is offline
    Jan 2007
    359.9bhp astra
    very tidy
    Mar 2009
    newcastle
    corsa xe
    Cheers for feed back ladds yes going to use Saab rad me and a m8 broke a full car for the running gear 4 year ago when we would have been the second one done a think? But never got it running just cranking over so never got around to do it and I always. Wanted one running so here I am round 2 with a van this time just this time wirring is sorted along with the stage 2 going to get the wet gass up and running just to try it on the strips cheers agin
