What can I say other than ooops I've bought another project car lol
Recently I decided I was in the market for a run around but I did not want anything expensive or boring and most definatly did not want a project car lol, on the whole that limits your choice quite alot.
when I saw this on eBay I pretty much made my mind up on the spot I was buying it.
An Astra gsi with a Saab b204 engine conversion running mot'd and taxed perfect.
I only have the pictures from the add at the moment but I'll get more up as I go along
The car sounded perfect and like it was 99% finished with the only real problem being it smoked its tits off well after a good look around it is deff more project car than i first expected but then I guess deep down I knew that would be the case, it was to cheap to be finished in reality and the key thing is the engine is fitted starts drives and the car is mot'd so is a moving project.
The main object with this car is to make it into a nice daily driver on as cheap a budget as possible THIS IS NOT A GTE REPLACEMENT !!!
The first job was to find out why it was smoking so much all the symptoms said turbo so this was the first place to be checked the car came with a spare turbo that also smoked pretty bad so I took this and the car around to Dewis and had him weld up one of the hot side snails to enable us to check it was 100% turbo or engine
Even when he is doing a quick job he cannot help but do awesome welding
The good news is with this fitted the car is completely clear of smoking so it just needs a new turbo (pm me if you have a cheap t2 /t3 footprint turbo)
With that sorted and the car now running NA until I can find the turbo it was time to have a look around the car see what else I could spot with a quick look the following were found
Passengers side rear light not working
Number plate lights not working
Indicator relay constantly energised
Both indicators constantly on, on dash
Oil pressure gause not working
Speed intermitently working
Fog lights not working
Front suspension has no movement
Been fitted with Saab lower arms bushes nackered / track far to wide
Exhaust only has one motorbike can far to noisy ( I must be getting old lol)and blowing quite bad
Steering wheel loose
Seat loose maybe missing bolts
I don't think this list is going to be exhuastive by any stretch of the imagination, the good news is so far its all time based not money which fits in prefect with the objectives of the project.
My nans down for the next week so I won't be getting much done over that period but I'll obviously update as I do.
i can see this seriously spiraling out of control lmao
