well the car didn't get started today.
I went to the lock up around 8.00 ish, finished off a few bits like the inner arches need to go on, the side skirt, wipers. then pushed the car out in to the yard, disconnected the turbo oil return, removed the spark plugs and fuel pump fuse. and tuned the key!!!
and nothing!
just went tick....once!
so removed the battery leads right quick! went all over the car checking,.... found nothing.
so put it down to flat battery. so I pinched the battery off the Astra, connected it up and turned the key again!..
and she spunand spun.......and spun......and spun a bit more.....and no oil from turbo return
so I removed the oil feed pipe at back of oil pump and spun again. nothing!![]()
so I removed the oil cooler pipes, nothing come out!
so I removed the oil filter! (why is it when you do a filter up by hand you cant undo it by hand!! >:| ) anyway nothing come out!![]()
so wondering if it was struggling to pick up the 20/50 oil (which is quite thick) so I drained the oil, and filled with 10/40 and spun again. still nothing! at this point I was quite pissed off and concerned about things!
so I made a phone call or two, (since this is the first time Ive ever done any of this!) I was asked/told that I should of filled the oil pump with oil when putting it together! (so it was primed) I didn't do that! )
so I tried to fill with oil via a syringe in every way I could and this didn't work either!.
So off with the exhaust and sump, removed the pick up pipe, and filled the best i could from there.
put it all back together (leaving oil filter off) and spun again...........
oil pissed out!! YAY! (Ive never been so happy to oil pissing out from under my car be for)
screwed filter back on and spun again and there it was! Oil from the turbo return TFFT!
BUT..
where I had to use a chain whip to get the filer off, Id punctured it so oil leaks out the side of filter now!
by this point it was 5.00 and I hadn't eaten anything all day. so I came home.
at least I have the oil primed now!, and tomorrow I need to get another filter, drain the 10/40 out, put some 20/50 back in and check that that still pumps through. then fingers crossed start her up!
Id like to say a massive thanks to C20letian! If you hadn't mentioned priming the turbo (which even though Id heard/read about long time ago) I wouldn't of done today and Id be sat here in tears with a ****ed engine! massive thanks to you Ian, you have saved my car!
i wish you had painting the rear diff, school boy error on your part lol, she looks awesome you should be super proud mate
