Had this for about 9 months now, its the most versatile car i've ever owned and probably one of the least rusty lmao
The first few posts by me are copy/pasted from another site that has followed the car since I bought it, so there will be continuity errors but it should all make sense!! Also there will be a few references to people on the Total Carlton website, just ignore that!
Spec: 1993 Vauxhall Carlton Estate
2.0 8v 115bhp engine and manual 5-speed gearbox (rear wheel drive)
Usage and goals:
Daily driver. Goals are comfort, cheap style, good fuel economy and ability to tow and transport gear.
Modifications to date:
Vauxhall Vectra-C 16" structured 5-spoke steel wheels, front standard, rears are reversed with 205/45/16 tyres
Custom made coilovers up front with 225lb 2.5" coil springs and Vauxhall Calibra factory dampeners, 80mm drop
Vauxhall Carlton GSi3000 saloon rear springs and standard dampeners on rear, 70mm drop
Middle exhaust silenser removed, stainless backbox and letterbox tailpipe added
CarPC with built in touchscreen
Future plans:
Matt Black vinyl wrap
Different engine (possibly 4.6 V8 on LPG)
When I bought it for £400:
Prototype coilover:
Lowered:
Steelie mods and fitment:
Latest images:
A little update on the estate, despite feeling a little crappy I pushed through it and got a fair amount of work done.
First job was to find a solution to the exhaust bottoming out on speedbumps, rocks, twigs, raised tarmac or cats eyes. A large section consisting of the downpipe up to the cat hangs about 2 inches below the chassis line, first thought was going to require cutting and welding this section higher. In the end I had a brainwave and decided to space out the N/S/F engine mount with very large washers, this did the trick and the exhaust section only hangs down about 1/2 inch now
Other jobs I did today were fitting the rear 1/4 trims (these aren't 100% perfect but certainly an improvement), de-badging the tailgate and a pretty controversial modification was to paint the text on the tyres with white tyre paint.
The estate hasn't been modded much recently, all I added was an electric radiator fan. I have however been using it a lot and here are some cool pictures from a little road trip this sunday.
My estate Vs a standard ride height estate:
Just got back from a Rolling Road day at Janspeed, wasn't planning on running but when two people didn't show up (but had paid deposits) I felt it was rude not to use their deposits for a go lol
Very chuffed with the results, the engine itself didn't blow any smoke out the exhaust and made 99.21bhp and 113.18ft-lbs of torque at the wheels (at a guess i'd say I loose 20bhp through the transmission) so around 119/120bhp at the flywheel is a good guess. The factory output is 115bhp at the flywheel so its all smiles.
Not much been done recently, had to do a lot of work to mum's XE calibra but I was rewarded with a no advisaries MOT certificate!!
I did however manage to do a few things to the Carlton, but the MOT and Tax expire next week so I needed to give her a fighting chance of passing.
First issue is the rear wheels, as you all know I reversed them and they run very close to the outside inner arches, so much so that when I had three no-so skinny peoples in the back it rubbed like a mofo and de-laminates the top layer of rubber on the sidewalls. Thats an MOT epic-fail!!
The rears have covered around 5K miles already with the silly camber so there is only 2K left maybe in them, but I am cheap so want to use them till they are dead!! So I borrowed the Lotus front wheels:
As part of the planned colour change I plan to remove the washer jets from the bonnet, so first up stealthy replacements were needed, I had my Insignia fan-spray jets left over from my Astra Coupe and I decided to install them in the same manner the Astra-G's have them. I also fitted a shorter passenger wiper blade and moved the wiper arms so they sit underneath the bonnet when parked:
Much better:
Not sure if you guys will be able to see this video as its on FB but:
Welkom bij Facebook - Meld je aan, registreer je of ontdek meer
18 years old, nearly 110K on the clock and make 2bhp more than factory specs (no mods to engine) and not one little whiff of smoke. Vauxhall engines for the win
