Nice car that mate!
This is gonna be awsome
Nice project here mate, sounds like youre pushing for big power, hope it all works out, shall keep an eye on this 1![]()
yes aiming for about 380-400bhp, im more interested in being able to use the power rather than high hp figures. ill be using the gt2871r with the 64ar exhaust housing to keep the lag down.
ill be ordering regals inlet and exhaust cams next month which should give good gains.
4 new toyo t1r tires this month, mtec vented and grooved front disks, yellowstuff pads front and oe rear as i have no tread or brakes lmao
468BHP AND 444TORQUE (REGAL TUNED AND BUILT SLEEPER)
looking good Big power![]()
INSTALLING SUMMER... ████████░░░░░░░░44% DONE. Installation failed.
404 error: Season not found.
oh yes and finially decided what turbo a gt3071rs
changed my mind again ordered at gt2871r 86ar for the improved response
also ordered steve miltons custom spec high lift cams to help with sustaining power top end and should allow a big more ignition advance in the map
We'll after talking to chris and ryan at regal the car is now going in there instead of mpg on 4th feb to be left with them while I'm working away for 10 weeks. They are going to rebuild my engine using my parts, fitting my nortech kit and gt2871r 86ar. Going to run the engine in properly for me then map it with my siemans deka 630s. So its drive in with 300bhp and drive out with over 400 all being well lol
heres the spec
head:
arp head studs
heavy duty valve springs
cometic wrc headgasket 1.3mm
steve miltons custom spec cams 10.5mm lift
bottom end:
cosworth 86.5mm pistons
steel h-beam rods with arp
new and uprated bearings
ballancer shaft delete kit
bmw under piston oil jets
lightened and ballanced bottom end
all new gaskets
new oil pump, water pump and cambelt kit
courtenay clutch rated to 400 torque
turbo setup:
gt2871r 86ar
nortech equal length tubular mani
nortech chrome inlet pipe
nortech down pipe
larger 90mm core intercooler with 2.5in pipweork
twin core alloy rad with cool stat
current spec
eds 3.5 running just over 300bhp
vxr turbo
vxr injectors
eds inlet manifold with tophat
3in cobra turbo back exhaust system with sport cat
cdti airbox kit with k and n
beeson intake on its way
regal fuel pump
fse power boost valve
tx smaller fmic
samco everything under the bonet
regal power pipe
i pick it up full mapped and run in on the 2nd may mate, not ready for shows yet as its getting a full respray first possible in audi shell white. uprated brakes and a few interior mods. skint know for a few months lol. should be finished for trax
anyone seen a nurburgring astra coupe? ha ha watch this space
Oh right, ok cool. Will look nice in white, haven't seen one
think ther are 2-3 knockin about just hard to make these stand out from the crowd. love the white corsa bet that shifts
Yea it does mate, raced my mate in his phase 3 z20let & i leave him, even though im boosting at 9 & hes boosting at about 15 on a vxr turbo. Turns a few heads but looks very average compared to barnes & bigron's lol Just like a go kart, its a lot of fun![]()
yeah i love it, you would probs be faster than a fair few high power cars being so light with that power
Really like this motor, lovely colour too![]()
V6 Ste on VVOC.
cheers mr gsi heres the spec, results to come in next 2-3 weeks
Built and tuned by regal
Current spec
Head:
Steve Milton custom high lift cams (made by piper)
Steve Milton’s heavy duty valve springs
Steve Milton ARP head studs
Athena/pec 1.3mm wrc spec head gasket
Bottom end:
Cosworh 86.5mm forged pistons
Steel h-beam rods with arp
Balancer shafts deleted
Under piston oil jets
Bottom end balanced
Re-bored and honed
All new gaskets
Oil pump
Water pump
Cam belt kit
AC deleted
Drive train
Regal Sachs paddle clutch kit
Regal billet lightened fly
Arp flywheel bolts
Fuelling
Siemens deka 630 injectors
Regal FSE reg
Regal uprated fuel pump
Turbo setup and intake + exhaust
Nortech gt2871r 86ar turbo kit
Modified cobra 3in turbo back exhaust with sport cat and two silencers
Forge dump valve
Regal v-flow intake with 90mm maf
Eds inlet manifold and tophat
Cooling
Twin core alloy rad
Cool running stat
Aftermarket evo 8 intercooler with 2.5in boost pipes
Regal mocal oil cooler kit (not yet fited)
Being run in now at regal before custom map
here is power graph, reg is being changed to smoothe out the fueling as its a bit lazy will upload final graph once finished
