Lacetti (chevy) - c20let project
Page 1 of 2 1 2 LastLast
Results 1 to 25 of 31
Thread: Lacetti (chevy) - c20let project
    Feb 2011
    Maltese Islands
    rebuilt c20let
    I have bought a c20let engine, stripped it down and built it up the proper way.. Soon will be putting it in the engine bay
    Engine spec:
    low comp pistons & Ceramic coated
    std rods
    ceramic coated bearings (main & Big ends)
    ARP main and big ends
    std head gasket
    skimmed,ported and polished head
    xe cams and vernier pulley
    Bosch green injectors
    std intake manifold
    custom exhaust manifold
    garrett t34
    lightened flywheel and balanced bottom.
    frount mount ic
    oil cooler
    sard fuel regulator
    KMS ecu
    f23 gearbox with quaife lsd.
    By c20let_matt at 2011-08-05
    When It comes to motorsport its what you build not what you buy
    Feb 2011
    Maltese Islands
    rebuilt c20let
    Re: Lacetti (chevy) - c20let project
    Currently waiting for the clutch slave cylinder. As soon as it arrives the gearbox will be bolted to the engine and find its place in the car Meanwhile I am customising the std seat rails to fit 2 new omp bucket seats and doing some body work.
    Jun 2002
    Wrectum
    Shuvit, e36 track car
    Interesting, good pics
    what's a Lacetti though? Is it the same as we have, the one that Plato crashes every weekend in the BTCC?
    Feb 2011
    Maltese Islands
    rebuilt c20let
    Quote Originally Posted by Tathan View Post
    thanks.
    Lol yes but mine is hatchbk. Completely diff shape.
    Jun 2002
    Wrectum
    yeah I know the one. It's just Chevy/GM have a habit of using the same name in UK/Europe/US/Aus/etc for different cars and then different names for the same cars lol
    Will be interesting to see when finished - what do they handle like?
    Feb 2011
    Maltese Islands
    rebuilt c20let
    As standard they are not bad although when I lowered it by 35mm (apex springs)i saw an improvement. I bought mine with the 1.4 (they are not a very good fuel savers and a bit heavy, maybe that's why) When I removed the 1.4 and put the let for the first time to see what mountings I need the car had more clearance (mudguard arch to wheel) with the let than with the 1.4 which I wasn't expecting.
    Edit : maybe thats why they tend to suffer from some understeering as they are a bit heavy at the front, although even modern vauxhalls seems to have same prob of usteering.
    In the near future I might get a new set of BC coil overs but first will see how it handles as it is with the lsd.
    Nov 2007
    Belarus
    Vectra 2000 20XEJ 90
    . is it evo`s?
    sorry for my BAD english
    Vectra 2000 = Calibra
    Feb 2011
    Maltese Islands
    rebuilt c20let
    Quote Originally Posted by DeimonNG View Post
    . is it evo`s?
    No it was built in here (Malta), I bought it with the engine. It is constructed from elbows welded together and smoothed.
    This looks like a very fun build.
    Jul 2005
    Tiptree Essex
    PACE/COURTENAY 1.8 GTE
    Excellent work mate, going to keep an eye on this one!!
    Feb 2011
    Maltese Islands
    rebuilt c20let
    Thanks all for your comments
    Just received the bearing this morning !
    Uploaded with ImageShack.us
    Northeast Kent
    awesome project i like your solution for the oil return to modify oil level sender plate.
    will this be ok as it is under the oil level in sump ?
    Feb 2011
    Maltese Islands
    rebuilt c20let
    Quote Originally Posted by DarrenH View Post
    Thanks. It should work as it is at the upper part of the sump and while engine is running the level will be a little shallower and also pressure in the pipe will push it downwards
    Sep 2004
    Greece
    tigra/LET westfield
    Great project,they are very popular around here,and undercover too
    MIG.....Made In Greece LOL
    Nov 2005
    Chester - North West
    Vectra C CDTI
    fantastic read there well done!
    MIGClub Member Grant_nova's Avatar
    Sep 2005
    Wrexham north wales
    novavan
    looking good pal!
    why be a hero, when you could be a ledgend!!!!
    Feb 2011
    Maltese Islands
    rebuilt c20let
    Thanks everyone!!
    Some updates
    Feb 2011
    Maltese Islands
    rebuilt c20let
    it's been a while since i last posted but work has continued and nearly finished
    here's a video of its first start, without exhaust and the tappits sound loud but they have cleared and sound smooth
    not top quality but that's what i got
    http://s1230.photobucket.com/albums/...ent=C20let.mp4
    now getting the bumpers ready and will do some running in
    MIGClub Member Corsa_LET's Avatar
    Sep 2011
    Nottingham
    Astra z20let sleeper
    Wicked great build mate & glad it started & runs smooth (not all do after a rebuild lol) very rare aswell, never heard of 1 being done before. Will keep an eye on this
    Feb 2011
    Maltese Islands
    rebuilt c20let
    Quote Originally Posted by Corsa_LET View Post
    thanks! yes i was anxious till it started..cranked it for a while till oil got up to the cams and was happy to see the oil press gauge climbing to 75psi as it started
    That's looking very good dude.
    Jan 2012
    Very nice mate, can i ask what engine mounts you used as my Kalos has the same 1.4 engine and mounts, and a turbo conversion was one of the things i was concidering.
    Cheers jonny.
    Feb 2011
    Maltese Islands
    rebuilt c20let
    Quote Originally Posted by Jonny sx View Post
    Cheers jonny.
    Thanks, I have made the mountings myself. Designed them with carton before and then machined them (about 3/4 of a cm thick). Also reinforced the front end with a flat bar that's bolted from side to side. Also made a new mounting on it which bolts together the gearbox and engine (under engine number). All mountings bolt in the car in their original place (except the front mount) and aren't solid.
    They took me a lot of time to design them and to make them as strong as possible, but now that I am driving the car it still feels like standard and no vibration at all
    Edit: the front mounting together with the front end re inforcement can be seen in the pics.
    Jan 2010
    Hemel Hempstead
    Vectra B C20let
    Awesome build, congrats on doing this.
  26. #25
    Feb 2011
    Maltese Islands
    rebuilt c20let
    Thanks Mike
    Dyno day is booked for 7th march. Can't wait to give it a proper map and some boost !!
