full engine rebuild - LET Calibra 4x4
Page 1 of 3 1 2 3 LastLast
Results 1 to 25 of 53
Thread: full engine rebuild - LET Calibra 4x4
    MIGClub Member c20letian's Avatar
    Jul 2009
    Kent
    Calibra 4x4
    hey guys just thought id put up some pics of my car and what in doing to it...
    http://i1131.photobucket.com/albums/...ndegia/car.jpg
    http://i1131.photobucket.com/albums/...ginebaytwo.jpg
    http://i1131.photobucket.com/albums/...oscasthead.jpg
    im hoping to get the engine out soon and give it the star treatment.
    MIGClub Member RodOGW's Avatar
    Jul 2009
    Norfolk
    Calibra 2.0i 94
    Re: full engine rebuild
    Get too it and get it back on the road - the world needs more Vauxhall Royalty on the road and not in scrap yards being cannabalised... Good luck with it
    Jul 2009
    Kent
    Calibra 4x4
    thanks mate.
    Jul 2009
    Kent
    Calibra 4x4
    Apr 2010
    Northern Ireland
    cavalier sr1 v6
    nice 1 mate love seein engines in bits
    Jul 2009
    Kent
    Calibra 4x4
    Jul 2009
    Kent
    Calibra 4x4
    finally got the crank bolt out lol
    http://i1131.photobucket.com/albums/.../Photo0084.jpg
    Oct 2010
    corsa B
    Re: full engine rebuild - LET Calibra 4x4
    any plans for the faded body work?
    Dude, if you copy and paste the img code the pics will show up like this...
    Jul 2009
    Kent
    Calibra 4x4
    thats so cool. thanks mate
    Jul 2009
    Kent
    Calibra 4x4
    hey guys i got a meter of 12mm studding, nuts and washers to bolt it to the stand.
    Jul 2009
    Kent
    Calibra 4x4
    Aug 2011
    Suffolk
    calibra turbo
    going well there chap, what plans or aims have you got for the car/engine?
    relyabilaty? big power?
    will be following this
    Jul 2009
    Kent
    Calibra 4x4
    thanks mate. the car will look the same as it does now and the money will be spent mostly on the engine and bay. i will get a txb locking kit and hopefully a l.s.d on the back axial.... im looking for about 300-350bhp but first i will be cleaning the casting flaws from inside the block and will be replacing the rods for better ones and replacing all the bolts for arp ones. at first i was only going to replace the rings and bearings but now im going to take my time and give it the star treatment... im still not sure about what turbo or manifold i want it to have but in time im sure ill think of something.
    ian
    Aug 2011
    Suffolk
    calibra turbo
    I feel what your saying, I took mine off the road so I could treat any rust I found and give it all a good clean up. then I found myself taking the engine to bits. started with oil leak. now like you its getting new this new that.
    I've looked at locking the box. but mine is all working at mo. (for how much longer, I'll and no man will know) the bit that puts me off is if the car breaks down it cant be tow'd on a dolly trolly! not sure if its ok to tow with all 4 wheels on the ground or not!?
    any way keep them pics coming
    Jul 2009
    Kent
    Calibra 4x4
    this is what iv done so far today. now im about to take out the crank...
    ian
    pie
    pie is offline
    May 2009
    blackwood
    Cavalier GSI 4x4
    looking good buddy
    im sure you can tow with all 4 wheels on the ground with a lock box
    Jul 2009
    Kent
    Calibra 4x4
    and now the crank is out. nice empty block to play with...
    Aug 2011
    Suffolk
    calibra turbo
    Thanks for that pie,
    are you having it re-bored or just a hone? mine is at same point and going for a hone this week.
    Jul 2009
    Kent
    Calibra 4x4
    i want to use the same pistons because i hear there good for 500bhp so a light hone will do. im about to go on ebay now and splash some cash lol.
    btw how did you get on with that link i sent you on the thread you started??
    Aug 2011
    Suffolk
    calibra turbo
    Same here, hone, new rings, shells and slowly going back together.
    As for the max boost link, Yer its a great site. had it in my bookmarks for a few years. along with cav16 Cav16 - Cavalier/Calibra 4x4 Transfer Box Reconditioning Service
    Still undecided on what to do about it, still reading this and other forums.
    You going down the cosmetic gasket route?? I'm not. been looking for bottem end gaskets for a while and today this popped up.
    eBay - The UK's Online Marketplace
    and this for top end
    Got all the valve stem seals with that set!!which I wasn't planning to do! but well what the hell I may as well now! lol
    HTH
    Jul 2009
    Kent
    Calibra 4x4
    when redoing the valve steam seals be sure to rap tape around the top of the valves so the seals wont get damaged when fitting. the gasket sets look good but id use a one piece sump gasket and one of those 3 layer steel head gaskets..
    Aug 2011
    Suffolk
    calibra turbo
    thanks for tip on stem seals.
    Looked at other sump gaskets but was unsure if they where any good.
    how much did you/looking to pay for head gasket?? its not to late for me to change
    Jul 2009
    Kent
    Calibra 4x4
    i fitted one in the past and never had any problems and i got another because i cocked up the valve steam seals.. i think i paid £30 each of ebay. there made by elring and you have to remove a couple of the brass rivets before fitting.
  26. #25
    Jul 2009
    Kent
    Calibra 4x4
